Old 09-19-2010, 10:35 AM
james34bev james34bev is offline
please help diagnose jimmy
had codes checked at auyozone i do not know where to begin jimmy will start seems to idle okay but when you give it gas it starts to miss and picks up really slow and when you let off the gas it tries to stall sometimes and sometimes it will stay running any clues would be helpful
Old 09-19-2010, 10:52 AM
jdl jdl is offline
Re: please help diagnose jimmy
What year, what engine? Were there any applicable trouble codes? What were they? Use a gage and check fuel pressure. Some of the national brand autostores used to loan out a fuel pressure gage, if you don't have one.
Old 09-22-2010, 09:23 AM
it is a 2000 gmc jimmy sle 4wd 4.3L the codes it is giving me are PO300 random misfire detected. PO302 cylinder 2 misfire detected. PO452 evaporative emission system pressure sensor switch low input. PO106 manifold absolute pressure baro service range performance. jimmy will start as soon as it starts you can tell its not right it will idle pretty smooth but when you give it gas it picks up really slow and is missing when you let off the gas it will sometimes just die and sometimes it will kind of stall but it will keep running and idle will smooth out
Old 09-23-2010, 06:02 PM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
YOU HAVE A MISS ON NO 2 CYLINDER.
Check plugs and wires for good spark.
And map sensor or wiring or vacuum to it problem.
Check for good vacuum to it.
And see if it is reading voltage to ECM.
Ge a repair flow chart for code 106 and go threw it.
MT
Old 09-23-2010, 11:06 PM
Rick Norwood's Avatar
Rick Norwood Rick Norwood is offline
Big Tall Dumb Ass
When was the last time you did a full Tune up, Plugs, Wires, Distributor cap and Rotor?
Check your Gas cap for a cracked Seal.
"If everyone is thinking alike, then no one is thinking". - Gen. George S. Patton Jr.
