Go Back   Automotive Forums Car Chat > Chevrolet > General Discussion
Old 09-19-2010, 10:23 AM
ffgus ffgus is offline
Oxygen Sensors
Hi Everyone.
My 2005 Chevrolet Avalanche has the P0060 diagnostic trouble code. HO2S, Heater Resistance (bank 2, sensor 2). Will simply replacing the O2 sensor after the converter on the right side of the vehicle solve the problem? I think I checked the correct fuses on the fuse block under the hood, 15 amp, O2 sensor, not blown. I read some articles on making sure voltage is correct and that there are not any shorts in the wiring. Are the shorts that could be in the wiring harness solely on the 4 wires that go into the O2 sensor itself?
Maybe too many questions. Thanks for the help in advance.
Gus...
Old 09-19-2010, 01:05 PM
maxwedge maxwedge is offline
A990 racer
Re: Oxygen Sensors
Check for 12v and ground key on engine off, at the the wires at the sensor. In the future post this in the Avalanche forum below.
Old 09-19-2010, 01:22 PM
Re: Oxygen Sensors
Thanks for the info. I posted it here because this is more specific as a GM code, not nessessarily specific to the Avalanche model. O2 sensors are on every vehicle, not just Chevrolet Avalanche. I get more viewers in Chevrolet, nonspecfic, than in just Avalanche alone.
Old 09-20-2010, 10:05 AM
777stickman 777stickman is offline
Re: Oxygen Sensors
For trouble shooting you might swap the #2 sensors from side to side, clear the code and see what happens.
57 Chevy 210
65 Olds 442 Convertible (Another one sold)
75 GMC Vandura 3/4 Ton
1999 K2500 Old Body Style Suburban (Gone but not forgotten)
05 Dodge Ram 3500/5.9 Cummins
2012 Toyota FJ Cruiser
