Go Back   Automotive Forums Car Chat > Ford > Bronco
Old 09-17-2010, 05:26 PM
bronco72 bronco72 is offline
89 Ford bronco not firing
i have fuel and spark. The fuel pump die on me so i put a high pressure pump in the tank fuel pump kicks on getting fuel to the fuel rail. im just not sure if the injectors are firing now. is there any way to check that with out a node light. or could it be the pcm. any idea would help thanks.
Old 09-17-2010, 10:52 PM
mechhound mechhound is offline
Re: 89 Ford bronco not firing
You could spray some starting fluid in the intake by the air filter and crank it over. If you get a pop out of it, you'll know the problem is with the fuel delivery or possibly the injectors not firing as you mentioned.
You say you put a high pressure pump in the tank. Didn't the '89 models have a low pressure pump in the tank and the high pressure pump on the frame rail?
Old 09-18-2010, 04:53 PM
i am getting spark, i do get it to fire a little with starting fluids. and yes its a 94 pump. i guess if it is the injectors im not real sure on what to do now the pcm feeds the injectors power. im still not sure if there getting power but i dont want to go spend 30 bucks on node lights to see if there work if they are im not sure were to start and the same if there not.
Old 09-25-2010, 07:04 PM
rhandwor rhandwor is offline
http://www.autopart.com/tools/toolsmain/tool/T_3411.htm
Most parts stores sell Ford,Chevy,and Chrysler noid lights. The kit number is3401
A 12volt test and small gem clip will work. If no light a fuse or relay is bad probably EEC-IV relay. If it lights but doesn't blink a bad wiring harness is probably defective or unplugged. Possible ECM
