Go Back   Automotive Forums Car Chat > Kia > Sportage
Old 09-16-2010, 10:00 PM
Markb873 Markb873 is offline
front hubs
2000 Kia Sportage, front hubs are locked. The front driveshaft keeps turning out of 4 wheel drive. I dismantled, cleaned, and re-greased the hub locks. Permatexed them back on. They are still locked. There is vaccuum going to the hubs just cant get them to unlock..
Any ideas???
-Mark
The cars on the lawn:
2000 Kia Sportage
1993 Chevrolet S-10 Blazer
1975 Radio Flyer Wagon
Old 09-23-2010, 06:59 PM
RahX RahX is offline
Re: front hubs
If they are getting vacuum, they probably aren't holding vacuum. I know they have revised/updated hubs for a similar condition.
Old 09-30-2010, 04:15 AM
LMP's Avatar
LMP LMP is offline
Re: front hubs
Vacuum applies the hub, so they do keep vacuum. Check the solenoid valve: it is either blocked open or dirt keeps it from closing completely. www.avigex.ca/kia/vacsol.jpg Disconnect vacuum hose to hub to see if it will release.
...or, just as mine when I bought it, the hubs have been "inverted", that is, the spring inside the hub that is supposed to release the hub has been switched side and keeps the hub applied. Kia service used to do that as a solution for hubs that leaked vacuum and did not apply.
'93 Ponty Transport 3.8; 2011 SUzuki SX4 AWD (wife's) ; 2015 Sorento 2.4 AWD 1928 Graham Paige Model 629
I don't believe in miracles.
Old 10-05-2010, 03:16 AM
GuruMe GuruMe is offline
Send a message via ICQ to GuruMe
Red face Re: front hubs
So how did you manage to oevrcome this situation..or you still have your car locked?
Water filters - WIX filters dealer
Old 10-12-2010, 04:27 PM
wineaux wineaux is offline
Re: front hubs
My '01 Sportage had a very slightly leaking hub solenoid that would allow the hubs to momentarily lock when slowing for a stop light. Just a quick "bang!" then release. $25 solenoid from the dealer fixed it. It's located up near the master cylinder, easy to change.
Old 11-09-2010, 11:25 AM
Re: front hubs
Sorry guys, I forgot I posted this thread! Anyways mine was pretty simple. The return springs were missing out of the hubs. Apparently when the vaccum lines broke someone took the springs out of the hubs to keep them locked. All is well Thanks a bunch.
-Mark
2000 Kia Sportage
