Go Back   Automotive Forums Car Chat > Lincoln > LS | MKZ
Old 09-16-2010, 09:52 PM
JTsmks JTsmks is offline
Evap temp sensor location
Hello all. New here and have a problem. My 2002 LS has begun going hot from both sides and when running the test I get the error code denoting a "evap temp sensor short to ground" I've read a lot of past posts on this and have pulled both bolsters from the pass and driver side...the problem is I can clearly see the driver side temp sensor and the passenger side temp sensor but I'll be darned if I can find/see the evap temp sensor...i realize there are three total sensors but I can only locate the two. I tried pulling the radio/a/c control panel and upper vent with no luck seeing it that way either. Any guidance would be appreciated.
Old 09-17-2010, 06:49 AM
shorod's Avatar
shorod shorod is offline
SHO No Mo
Re: Evap temp sensor location
The Evap temp sensor is also accessed from the driver's side foot well. If I remember correctly, it's about half-way up the center vent area. It is interchangeable with the driver's and passenger's temp sensors. If it's truly shorted to ground, the problem is not likely to be the sensor but instead the circuit for the sensor.
-Rod
Old 09-18-2010, 07:54 PM
Found it...it was lower then I thought and hiding behind that "round" device....I switched it out with the drivers sensor and "fiddled" with the wireing....just drove the car on a 300 mile round trip to Orlando and back with no A/C problems. Now on to the valve cover gaskets and C.O.P's
Old 09-19-2010, 04:35 PM
shorod's Avatar
SHO No Mo
Congratulations, and thank you for following up on the thread!
-Rod
