Old 09-16-2010, 08:13 PM
nmtex87 nmtex87 is offline
Flickering lights '01 Blazer
My 2001 blazer's lights (all lights...dash lights, cab lights, and sometimes headlights) flicker...get dim and then bright. What might cause this?
Old 09-17-2010, 12:11 AM
viggy58 viggy58 is offline
Re: Flickering lights '01 Blazer
alternator?
hows your voltage look.
you can get the charging system tested for free at autozone...
2001 Chevy Blazer
4.3L 5 speed manual
Alpine deck, Type R 12in. sub.
145k miles
1997 Pontiac Sunfire
2.2L automatic trans
146k miles
Old 09-17-2010, 09:32 PM
mike2004tct's Avatar
mike2004tct mike2004tct is offline
Had the same thing with my '97.
Alternator tested good, and I had a new battery.
Belt Tensioner ended up being the culprit.
It was cracked, and eventually broke.
When that happened, there was no doubt what the problem was.
Replaced it, no more flickering.
It's my opinion, don't take it personal.
'04 T&C,'01 Blazer ZR2, '97 Blazer, '97 Sunfire, '85 Vette, '79 Civic, 94 FLSTC
Old 09-18-2010, 07:38 PM
laxman21's Avatar
laxman21 laxman21 is offline
HAd the same problem. Took the alternator out to check what regulator it needed and how to replace it, even removed all the screws that held it in until only the solder joints remained. Put it back together and back in and flickering was gone. Benn over 6 months.
Check all the connections.
'92 s-10 4x4 EC p/u
'99 Blazer LT
'99 Suburban LT
