Go Back   Automotive Forums Car Chat > Ford > Fusion
Old 09-16-2010, 01:19 PM
castilla's Avatar
castilla castilla is offline
check eng. light on P0446
i just had a buddy a autozone pull the code for me and it comes back P0446 EVAP something so long i couldnt remeber but i never had an issue with this car ever and now this happens after all but the driver door handles break. ive got a 07 fusion 4cyl warranty has expired due to mileage and im broke from helping my daughters car being fixed ( 1200.00 )
any help would be appreciated
Old 09-17-2010, 12:47 PM
RIP's Avatar
RIP RIP is offline
AF -Advisor
Re: check eng. light on P0446
If you're not experiencing driveability problems, and the chances are you're not, you can sit on this one a while. Other than having the check engine light on it shouldn't effect much. Course if your state requires a smog check then you'll have to get it fixed in order to turn off the check engine light and pass the test. Here's a link that explains your code. Your code is what's termed a generaic code meaning it applies to many vehicles and not just your fusion, therefore the terms for components are generic. Ford may have other terms for the same thing: http://www.obd-codes.com/p0446
FYI - You'll notice I'm an "Advisor". Most of my experience is on Chrysler and Toyota products with some experience sprinkled on other vehicles. I'm fairly new to Fords. Anything I post regarding Fords is based on general knowledge and what I've read on this and other forums over the last 7-8 years.
**We took the time to answer your post. Please give us some time and post the fix. It will help hundreds.
**Follow prescribed safety practices before attempting any procedures. Doubts? Consult a maintenance manual.
07 Fusion / 06 RAV4 / 06 Accord / 96 Gr Caravan
Old 09-17-2010, 12:48 PM
AutoService101's Avatar
AutoService101 AutoService101 is offline
That code is a vent control valve code. Chances are you need a new one (not sure of cost on that vehicle). Will not cause you any issues, try and clear the code and see if it comes back...
Do you ever over fill your full tank (when gas quicks pumping do you force a little more in)???
Visit my blog at : http://automotiveservice101.blogspot.com/
