Go Back   Automotive Forums Car Chat > Nissan > Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35
Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 Excellent platform and the good ol' VQ30DE and VQ35DE engines.
Old 09-15-2010, 11:20 PM
mandyjoger mandyjoger is offline
Lightbulb Whirring under hood when ignition turned on.
Whirring noise under the hood when you turn the ignition on. Seems to be coming from top of engine near rear firewall on drivers side. Continues whenever you sit at an idle. Seems to be getting more frequent. Happening for 2 months. What could cause this.
Old 09-16-2010, 01:54 AM
Nahkapohjola's Avatar
Nahkapohjola Nahkapohjola is offline
Re: Whirring under hood when ignition turned on.
If u happen to have nissan maxima (model?)... then:
Ignition on = engine may not be not running - if so, only possible noise is short circuit at ABS pump, cooling fan, Cruise ctrl pump (alas not near firewall). Pull fuses to check.
Idle = engine running. Typical whirring noise is power steering pump and/or belt. If noise comes from inside engine, top drivers side, there are only valves. Outside engine (?), maybe vacuum leak noise?
Needs some acute action like openin the hood. First buy 7$ stethoscope - listen, locate, search...
Maxima INFO pages was deliberately trashed (!?) by Cardomain; dont goto http://www.cardomain.com/ride/748507
There was a special Car Electronics -page http://www.cardomain.com/ride/748507/14
