Old 09-15-2010, 11:56 AM
kawala kawala is offline
88 Cherokee stalls sometimes
88 Cherokee 345,000 miles runs great on highway. But it has an intermite problem. It will stall sometimes and sometimes it won't. I can sit at a stop light for 2 or 3 mins idle just fine, then the idle will drop to 300 rpms them just stalls. I have replaced all the parts you here about on the internet. Such as plugs,wires,cap and rotor, TPS,idle position sensor,CPS,air filter,fuel filter,fuel pressure at fuel rail,map sensor and cleaned trottle boby. Sometimes when it starts to stall I have to pump the gas pedal fast and it will stay running. The only thing that I notice at high speeds is a slite hesitation. What next a new computer? I could use some real help with this. problem.
Old 10-18-2010, 02:00 PM
72mino 72mino is offline
Arrow Re: 88 Cherokee stalls sometimes
Maybe your ECU is going bad and isn't sending the proper 5V to the IAC (idle stepper motor, whatever you want to call it) and causing it to idle to low to keep running.
Could also be your fuel pump is starting to go bad, but since it drops to 300RPM, then stalls as opposed to the RPMs slowly dropping until it stalls it isn't very likely.
With it acting up intermittently I don't know how to test it besides replacing more parts, and I don't know about you, but I don't have spare $$ to throw away replacing good parts.
Dustin
