Old 09-15-2010, 06:56 AM
SDALLISON SDALLISON is offline
No brakes
Put on a new set of front pads pushed cals in w/c clamp no problem went to pump brakes up and now i have no brakes have replaced master cyl w/a reman and then replaced w/new bled brakes for ever it seems like and still no pedal if i pump them a lot i will get a tiny bit of pedal but after 30 second push pedal nothing please help
Old 09-15-2010, 10:46 AM
AutoService101's Avatar
AutoService101 AutoService101 is offline
Re: No brakes
Sounds like you have issue's. I am wondering if the brakes worked fine before hand?? You where just replacing pads I am assuming??
If so did you damage one or both calipers when you compressed them?? I would recheck your work!!
Visit my blog at : http://automotiveservice101.blogspot.com/
Old 09-15-2010, 03:53 PM
Re: No brakes
yes brakes were fine pads were just worn down no damage was done to cals the brake fluid was dirty i havebled about 1/2 gal through system every one says its air i m ready to give up
Old 09-15-2010, 04:11 PM
Re: No brakes
It could be air, sometimes it can be dificult bleeding the brakes. I would suggest at this point bring it to a tech to inspect. Stay away from the brake shops they are a rip off. Find a good local mechanic or spend the money to go to a reputable dealer.
Old 09-15-2010, 07:45 PM
Tony's Avatar
Tony Tony is offline
TLD Member #1
Send a message via AIM to Tony
Re: No brakes
Using a c-clamp to compress the caliper is a bad idea. Could cause dirt to go back up in the master cylinder cutting the seals in it. If you replaced the master cylinder then that knocks out that possibility, but throws in the possibility of the master cylinder having air in it. Did you bench bleed the master cylinder? If you did, make sure you are bleeding the calipers in the correct order...which I don't have a manual here in front of me to tell you, but I know Honda likes a criss-cross pattern and if you don't do it in that pattern, your just kind of SOL.
Tony
91 Civic Sedan DX - Stock 287k Miles
Old 09-16-2010, 10:08 AM
Re: No brakes
I did bench bled master cyl and bled wheels to the spec in a hayes manule now im thinking it maybe the proportinging valve dirt may be in there holdind a valve or vales open ?
Old 09-16-2010, 09:38 PM
BullShifter's Avatar
Re: No brakes
Bleed it at the master then go to the wheels.
