Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Suburban
Old 09-14-2010, 05:34 PM
mr moose mr moose is offline
to calibrate or not to calibrate that is the question?
i have a 1996 suburban 5.7 1500. if i replace the tps does it need to be calibrated and if so how is that done. thank you. mark.
Old 09-15-2010, 08:05 PM
777stickman 777stickman is offline
Re: to calibrate or not to calibrate that is the question?
My '98 service manual has no refences for calibrating the TPS after installation. Just pull the old one and put the new one on.
Usually a TPS will throw a code if bad.
Good Luck.
57 Chevy 210
65 Olds 442 Convertible (Another one sold)
75 GMC Vandura 3/4 Ton
1999 K2500 Old Body Style Suburban (Gone but not forgotten)
05 Dodge Ram 3500/5.9 Cummins
2012 Toyota FJ Cruiser
Old 09-16-2010, 08:26 AM
j cAT j cAT is offline
WHEN REPLACING THIS PART the manufacturer of that part will insert this "MAY require recalibration."
most times this is not the case.
ON other vehicles this would require a special scan tool . not sure on this older type.
what was the reason for this replacement ? tps dtc ?
