Old 09-14-2010, 01:44 PM
rotax30 rotax30 is offline
no electrical power any where.
96 blazer.no power anywhere,starter good,battery-13.4v..no head lights,no nothing.ecm or ign..?
Old 09-14-2010, 03:29 PM
Airjer_'s Avatar
Airjer_ Airjer_ is offline
Re: no electrical power any where.
Check the Fusible links down by the starter
Old 09-14-2010, 04:40 PM
old_master's Avatar
Advisor/Moderator
Start by checking the battery cables. Take both ends of both cables apart and clean them with a wire brush until they shine. Put them back together and tighten them up. Next check both sides of all fuses with a voltmeter or a test light, don't forget the Maxi fuse under the battery.
You have to know how it works,
to figure out why it doesn't.
Old 09-15-2010, 09:39 AM
Terminals was cleaned,no maxi fuse under battery unless i over looked it.Just cruise control diafram.I have 12v.to main + at the starter.The starter turns over when i cross the silenold terminals.no head lights.All fuses good.Turn the key over nothing...
Old 09-15-2010, 09:41 AM
I have 12volt power to the starter.(main battery wire)
Old 09-15-2010, 04:41 PM
old_master's Avatar
Advisor/Moderator
Check voltage on the red wire at the rear of the alternator.
Old 09-15-2010, 09:53 PM
Rick Norwood's Avatar
Rick Norwood Rick Norwood is offline
Big Tall Dumb Ass
This is sounding more like a Multi-function switch or possibly the Ignition Switch. If you turn the key on and jump the solenoid down on the starter, will the engine start?
"If everyone is thinking alike, then no one is thinking". - Gen. George S. Patton Jr.
Old 09-16-2010, 10:49 AM
no it won`t.What do u mean by Multi-Function Switch?
Old 09-16-2010, 12:32 PM
quote=old_master;6802291]Check voltage on the red wire at the rear of the alternator.[/quote] Have full batery voltage at the alternator...
Old 09-16-2010, 12:51 PM
Airjer_'s Avatar
of of the bck of the alternator there should be two wires. One of them goes back to the battery and the other will go to a junction block. That junction block will hav multiple fusible links coming out of it. Check for power at those wires.
Old 09-17-2010, 10:22 AM
Thanks AIR,i`ll get back to u.This for REX.Did u u put both wires back on alt?
Old 09-18-2010, 11:19 AM
Found it,the guy who put the alt.on left the black wire off.Thanks alot been alot of help.
