Old 09-14-2010, 10:35 AM
RinNC RinNC is offline
Taurus - P0401 code
I have a 1999 Ford Taurus. I received a check engine light code - P0401. The call out was to replace the EGR valve. I have done that, reset the computer and still getting the P0401 code. What should I do next?
Old 09-14-2010, 10:48 AM
shorod's Avatar
shorod shorod is offline
SHO No Mo
Re: Taurus - P0401 code
Try searching this forum for "P0401". There are a lot of solutions for this code. You might find the more common source is the DPFE or a vacuum leak.
-Rod
Old 09-14-2010, 11:10 AM
-Rod
What is DPFE and how would I check for a vacuum leak?
Rick
Old 09-14-2010, 01:02 PM
shorod's Avatar
SHO No Mo
DPFE = Differential Pressure Feedback EGR, it is one of the sensors that controls the operation of the EGR valve.
There are several methods for checking for vacuum leaks. The preferred would be a smoke machine, but a professional machine is pricey and home-brew methods are not necessarily simple. Another method would be to use throttle body cleaner or carb cleaner and spray it carefully around vacuum hoses and gaskets, being very careful not to get it on plastics or paint.
Again, a keyword search of the forum would yield this information and more specifics.
-Rod
Old 04-09-2011, 06:33 PM
Schaff68 Schaff68 is offline
My 97 came up with the same egr code, i had to replace the egr flow sensor, i got one at Advanced Auto Parts , after replacing the sensor, remove negative battery terminal, then the positive terminal, wait 15 minutes, put terminals back on and your check engine light should be off and the code will be cleared.
Old 04-09-2011, 09:26 PM
shorod's Avatar
SHO No Mo
The EGR flow sensor is the same as the DPFE.
-Rod
