Go Back   Automotive Forums Car Chat > GMC > Yukon
Old 09-13-2010, 11:23 PM
bigbookie bigbookie is offline
99 yukon won't stay running
i just had some head gaskets replaced and checked now that i have put everything back on my truck will not stay running unless i hold my feet on the gas i had the fuel pump, distributor and cap replace before all of this has happen also i replaced the ignition coil so can you tell me why my truck won't stay running
Old 09-14-2010, 03:38 PM
maxwedge maxwedge is offline
A990 racer
Re: 99 yukon won't stay running
Sounds like something was left disconnected or it needs an idle learn any check engine lite any vacuum leaks?
Old 09-15-2010, 01:05 PM
yukon6inchlift's Avatar
yukon6inchlift yukon6inchlift is offline
aircleaner assembly must be installed and have no leaks at all to run right unlike older cars. the dist could be off a tooth. i had issues w my spider injector right after i changed my intake gasket. is it giving a code? let us know what u find out please
Old 10-11-2010, 02:38 PM
it was my plugs and wires i had the cap and rotor replace now my #2 cylinder is misfiring but all the mechanical pressure is fine it is electrical i assume you have any suggestions
