Go Back   Automotive Forums Car Chat > Jeep > Grand Cherokee | Grand Cherokee SRT8
Old 09-13-2010, 06:11 PM
jer2266 jer2266 is offline
Automatic transmission trouble
i have a 95 grand cherokee w/4.0L anyways when i put it in drive it takes alot more than it use to of rpms to get it going when 1st starting out ive been starting out in 2 then shifting to drive when im going good ive changed the tranny oil and filter ug what can do this ?????? or what else should i try
Old 09-14-2010, 06:44 AM
fredjacksonsan's Avatar
fredjacksonsan fredjacksonsan is offline
Caution: Monkeys bite!
Send a message via AIM to fredjacksonsan
Re: Automatic transmission trouble
How many miles?
When you say you have to have more rpms, how many are we talking about?
You said you changed the fluid and filter, right?
Ours: 2020 Jeep Wrangler 2.0, 53k
2013 Toyota FJ Cruiser, 84k
Kids: 2005 Honda CRV, 228k
Old 09-14-2010, 02:38 PM
240,000 miles seems like motor is going but tranny is slipping a bit ive had tranny slippage before with a different car this doent seem exactly like that its more like the motor has the power but tranny doesnt until its up to about 30 mph ....yes trans fluid and filter changed
Old 09-15-2010, 09:02 AM
At 240K you might just need a transmission rebuild. I'd take it to an auto parts store and see if they can get any codes out of it....if everything is correct, then I'd guess a mechanical issue in the trans. If that's the case you could probably drive it awhile, but it would leave you on the road eventually.
Old 09-17-2010, 02:14 PM
mastertech1964 mastertech1964 is offline
i would look into a failed govenor pressure sensor and solenoid those are classic symptoms and its a pretty easy fix if you have a scan tool to use its makes diagnosis a snap otherwise its change the parts and hope for the best but thats where i would go with it
