Old 09-13-2010, 10:55 AM
J.C. Robbins J.C. Robbins is offline
Ford Windstar dies please help
My 02 windstar started dying about 3 months ago. It may go a few days without dying and it may die 3 or 4 times in an hour. It will quit at any time going at any speed although it hasn't died at an idle yet. I have had it hooked up to a diagnostic computer it gives no codes or problems. The fuel pump, fuel filter, fuel pump relay, crank sensor, cam sensor, throttle position sensor and the PCM relay have been changed. And I checked the wiring the best I could. Has anyone out there had this problem and been able to find the cause. I would really appreciate some help.
Old 09-14-2010, 07:51 PM
wiswind wiswind is offline
Re: Ford Windstar dies please help
Without any code(s), it is tough finding the problem.
I want to guess fuel, only because you have no codes......and I would expect something spark related to give you a code.
However, I am only guessing.
There are no sensors for fuel flow or fuel pressure.
However, there are a LOT of other things that it "could" be.
It would be interesting to try to monitor something, battery voltage as measured at the OBDII port....at the fuel pump...etc.
Moderator for Ford Windstar room only
Links to my pictures, intended as an aid, not a replacement for, a good repair manual.
1996 3.8L Windstar
http://www.flickr.com/photos/4157486...092975/detail/
2003 Toyota Sienna pictures (not much there yet)
http://www.flickr.com/photos/4157486...781661/detail/
Old 09-15-2010, 07:34 AM
Are you talking about the port under the steering column? Or is there another port near the fuel pump? Sorry for the misunderstanding and thanks for the reply.
Old 09-15-2010, 06:57 PM
OBDII port under steering column.
Also monitor the voltage at the terminals of the fuel pump.
2 different locations......to monitor 2 different values (is the power on the OBDII port there when the failure happens and then......is there power TO the fuel pump when the failure happens).
These are checks that don't require new parts......and will verify or eliminate areas that are the cause of the problem.
1996 3.8L Windstar
Old 09-16-2010, 07:10 AM
Thanks for your help. I am hoping that I have some time to work on it this weekend. I will keep you posted.
Old 10-04-2010, 08:46 AM
RESOLVED - I had the alternator checked, it was putting out a good charge but the frequency was jumping up and down and causing something to go haywire and shut the engine down. I have driven it for a week since changing the alternator and have not had any problems.
