Old 09-12-2010, 04:55 PM
MAD King MAD King is offline
A/C Compressor Replacing - How?
Hello,
my A/C compressor is leaking and therfore I need a new one. To let it done by a mechanic here would cost me over $600. So I decided to do it by myself.
The only problem is, I don't have a compressor for compressed air to dry the system after flushing. I live in Florida where it is very, very hot. So do I have to blow it out with compressed air or can I let it dry by the sun?
Thx
Old 09-12-2010, 05:32 PM
Blue Bowtie's Avatar
Registered Offender
Re: A/C Compressor Replacing - How?
You actually need to apply a vacuum instead of compressed air. The new compressor should be loaded with about two ounces of refrigerant oil. Once the new compressor is installed it should be turned by hand for several complete revolutions to distribute the oil and prevent compressor damage on startup. After that, the system needs to be evacuated and held at 27" Hg or greater vacuum for a minimum of ten minute to help remove any moisture in the system. If the accumulator has been cleaned out the remaining oil charge (about 4½ ounces) should be added at this time, then refrigerant can be added. System pressures on both the evaporator and condenser need to be monitored when adding refrigerant to make sure safe pressures are not exceeded until the system is completely charged (by weight).
It would be a very good idea to remove and clean out the accumulator and to remove and clean the orifice tube or just replace it (about five bucks) when replacing the compressor.
Old 09-12-2010, 05:45 PM
I have a new accumulator and a orifice tube as well, but it sounds very complicated. What tools do I need for vaccum it?
Old 09-12-2010, 07:06 PM
Registered Offender
You need a charge manifold, hoses, and a vacuum pump. This ought to get you by:
I just happened to have those out today for a Buick (compressor replacement).
Old 09-12-2010, 07:32 PM
UPS
You aren't living around the Space Coast here in Florida by chance?
K. I think I need someone who can do it. What do you think how much should it cost if I have all the parts?
Old 09-13-2010, 01:02 PM
I called a few shops here and the cheapest offer was $300. They said they needed around 4 hours to have it done. 4 hours?
I am tried to find some tutorial on how to do it on my own but couldn't find one.
Anyone who has one?
Thx
Old 09-13-2010, 10:04 PM
Registered Offender
As I mentioned, the old compressor should be removed. New sealing rings should be installed on the refrigerant line set which bolts to the back of the compressor. The new compressor is loaded with about 2 oz. of PAG oil then the compressor clutch is rotated by hand to distribute the oil. The new compressor is bolted into place and the belt is installed. All electrical connectors should be connected to the compressor and clutch.
The low pressure cutout switch is removed from the accumulator, then the low pressure line is removed from the accumulator and the accumulator is removed from the evaporator line so it can be removed from the vehicle. The high pressure line at the evaporator is removed and old orifice tube pulled out of the evaporator inlet. The new orifice/screen is installed, then the high pressure line is reconnected to the evaporator. The low pressure side of the evaporator is connected to the new (or cleaned) accumulator. The remainder of the oil charge can be added to the accumulator then the low pressure line to the compressor is reconnected to the accumulator. Alternately, the oil can be added with the refrigerant, but measuring it into the accumulator is a lot more accurate, and PAG oil is hygroscopic (will absorb atmospheric moisture) so it is important to install the oil charge before evacuating the system.
Once the system is sealed the manifold gauge set hoses are connected to the high- and low-pressure fittings and another hose is connected from the gauge manifold to the vacuum pump. The pump is started and the manifold valves are opened to subject the entire system to vacuum until at least 27" Hg of vacuum is achieved and maintained for ten minutes at a minimum. This will help purge the system of any moisture and air, and establish a test point for vacuum testing. The pump can be shut off and the gauges monitored for another ten minutes to make sure the vacuum holds without dropping (indicating leakage into the system and eventual leakage out of the system once refrigerant is installed).
If the system holds vacuum without leakage the vacuum pump can be disconnected and the refrigerant supply connected to the gauge manifold. The weight of the refrigerant cylinder is recorded and the engine is started with the A/C controls set to full cold. Refrigerant is added until the correct mass of refrigerant is applied and/or the system pressures are adequate for the given temperature conditions and system superheat.
Pretty easy, no?
Old 09-14-2010, 09:03 AM
Originally Posted by Blue Bowtie View Post
Pretty easy, no?
Yes, after your great tutorial.
I got it now.
Thx.
