Old 09-12-2010, 10:15 AM
lnkbart lnkbart is offline
99 voyager won't crank
Son replaced a starter, but got the starter sonenoid wire caught in the starter and bell housing.
straightened that out , but now it won't crank. good battery, The ETAX shutdown relay? just clicks constantly. what is the relay and what does it do? could it be part of the problem now? any help will be appreciated.
99' plymouth voyager,3.0 v-6
Old 09-12-2010, 11:41 AM
Airjer_'s Avatar
Airjer_ Airjer_ is offline
Re: 99 voyager won't crank
If you turn the key and hear repeated, steady clicks from the starter than the battery is probably low on charge.
Old 09-13-2010, 03:17 PM
RIP's Avatar
RIP RIP is offline
AF -Advisor
The EATX relay powers the transmission control module. Doubt that's associated to no starting. It sounds more like Airjer's thoughts may be the problem. Clicking relays is a sign of weak power. You say the battery is good. What makes you say that? I would get a set of jumper cables and jump start the battery. If it starts, have your battery charged or replaced.
**We took the time to answer your post. Please give us some time and post the fix. It will help hundreds.
**Follow prescribed safety practices before attempting any procedures. Doubts? Consult a maintenance manual.
07 Fusion / 06 RAV4 / 06 Accord / 96 Gr Caravan
Old 09-16-2010, 06:17 AM
thanks for the info. but no help. Battery is fully charged , specific gravity is good , 13 volts and tests good with a load monitor. The clicking is coming from the power distribution center, not the starter solenoid. no power to the solenoid, when you turn key to start.
starter relay in pdc tests good, fuse under dash is good. Is there another fuse ,relay or solenoid In the starting system?
Old 09-16-2010, 11:51 AM
jpb53 jpb53 is offline
This might help.
