Go Back   Automotive Forums Car Chat > Chevrolet > Camaro | Firebird > Firebird Discussions
Old 09-11-2010, 09:09 PM
transgta transgta is offline
Is it intake or head gasket
Ok my 89 gta has 40k miles.last couple summers ive lost very small amounts of antifreeze.This summer at startup it runs ruff for a minute an now shows signs of a little smoke.Antifreeze is getting thru somewhere.There is no sign of any in the oil.I jus now got intake off cant really see any visuals of it transferring from one port to another.I guess i just want an edgucated guess as to go onto heads or not.Ive never done it only thing not sure about is valves,valve lash etc.Does any of this have to be reset or adjusted.By the way it is a 5.7 tuned port.dave
Old 09-11-2010, 11:40 PM
89JustinH 89JustinH is offline
Re: Is it intake or head gasket
is it over heating real quick? or over time? and can you see any coolant stains down the side of the block??
Old 09-12-2010, 10:18 AM
It has never overheated at all no signs of antifreeze anywhere.i have heard the overflow bubbling a little when i shut it off a few times.also looking in the overflow i can see very fine metallic pieces an some dirty sludge in bottom.these flakes look like the inside of the tuneport mabe im jus not sure what to do
Old 09-12-2010, 06:52 PM
if it were a head gasket itd over heat and you would see signs of antifreeze on the sides of the block from my experiances, as far as the sludge and metal shavings im not sure on mine i replaced the thermostat and mine stoped bubbling
Old 09-12-2010, 08:50 PM
Im burning antifreeze.its mostly at startup idles ruff til it burns it out im lookin in the heads ports now and i see no antifreeze except where they should be.i guess ill put it back together with the new intake gaskets ans see what happens.
Old 09-13-2010, 01:02 AM
izzydjinn's Avatar
izzydjinn izzydjinn is offline
I think the seals need replacement. These seals are, in your motor's sides, and are metallic, round and slightly bigger than a silver dollar.
Is.... peanut butter jelly time, peanut butter jelly time, peanut butter jelly time, peanut butter jelly time.
Old 09-13-2010, 08:12 AM
wrightz28's Avatar
wrightz28 wrightz28 is offline
is bring'n sexy back
Freeze plugs, exactly what I was thinking.
However, if there are shavings in the overflow tank, perhaps the water pump is done.
Old 09-13-2010, 10:28 AM
izzydjinn's Avatar
Yeah, those....... thanks wrightz28, I just could not remember the name.
Old 09-13-2010, 03:46 PM
Thanks for getting involved.Now why would i b burning antifreeze out exhaust.where would it get thru.Is it possible the intake could allow it threw
Old 09-13-2010, 03:53 PM
by the way the shavings are almost microscopic.shining a light down in when i shake overflow it just barely glitters.It would go thru a screen
Old 09-13-2010, 04:28 PM
inafogg inafogg is offline
if your not seeing anything wrong with intake/gasket i'd pull heads
dont believe the freeze plugs are your problem
btw valves should be a torque to spec no adjustment
Live For Today
Yesterday is gone,
Tomorrows are'nt promised.
Old 09-14-2010, 07:42 AM
wrightz28's Avatar
As said, I'd suspect the shavings as a water pump problem. A freeze plug could be a (unrelated) problem with weeping, it does happen, the previous owner blew one out on my GTA and the replacement still weeps ever so slightly due to a lazy bum install job. Any point where the system is no longer sealed, lowers the boiling point of the coolant.
Before you go yanking the heads, get yourself a compression guage to confirm a head gaslet issue.
Old 09-14-2010, 04:43 PM
Ok wright can i do a test for heads with intake already off>?
