Old 09-11-2010, 08:38 PM
Riordan3 Riordan3 is offline
Thumbs down Windstar Driveability Problem
Engine will run then die but not stall then pick up again and repeat the whole process again. Acts like its getting starved for fuel. I checked the fuel pressure. Its takes a while for it to come up to specs when I start the engine.
Riordan3
1998 Windstar 199K( ex co car now Lowes hauling veh )
2004 Buick Regal 79K (wife's car )
2007 Dodge Grand Caravan 108K(company car )
2007 Mustang GT convertible torch red (my toy)18K
Last edited by Riordan3; 09-28-2010 at 08:47 PM. Reason: Not one reply on my problem. So I deleted the problem
Old 09-22-2010, 12:11 PM
jayjp200 jayjp200 is offline
Re: Windstar Driveability Problem
I have a same problem here. I also do not get many responses.
I did not get a chance to read it. Did you fix it. What was the fix.
Windstar is a weird thing and not one remedy works for the same problem.
Thanks.
Old 09-28-2010, 08:45 PM
I believe the problem I am having is the fuel pump. I have replaced the fuel filter, fuel pressure regulator. I got the tank down tonight but I can't get the ring off that holds the fuel pump in place on top of the tank. I soaked it with liquid wrench and went to Autozone to see if they had one of those ring wrenches. They didn't have one. Anyone out there know where we can get one of those wrenches. I am checking at Sears tomorrow. Any ideas on how to get a rusted ring off so I can change the pump?
Riordan3
Old 09-28-2010, 11:31 PM
serge_saati's Avatar
serge_saati serge_saati is offline
Send a message via MSN to serge_saati Send a message via Yahoo to serge_saati Send a message via Skype™ to serge_saati
Re: 98 Windstar surging problem
Maybe at CarQuest, NAPA or other auto parts stores. Or online. I really doubt Sears can have it.
Rusty ring are hard to remove. When I removed mine, I used a mattock. But it wasn't the best way, it tooks time.
2003 Chevrolet Impala LS 3.8L OHV
2002 Ford Taurus SE 3.0L OHV (sold)
1998 Ford Windstar LX 3.8L OHV (sold)
2002 Chevrolet Malibu LS 3.1L OHV (sold)
2004 Hyundai Accent GS 1.6L DOHC manual (sold)
1995 Oldsmobile Cutlass Supreme S 3.1L OHV (sold)
2002 Ford Crown Victoria Police Interceptor 4.6L SOHC (sold)
A Windstar without having the check engine light is not a real Windstar.
Old 09-29-2010, 01:30 AM
Thanks for the reply. If I can't find the tool, I may end up taking the tank to someone to have it removed. I don't want to damage the ring thats molded into the tank because now your looking at replacing the whole tank and they are expensive even though they are plastic. I may go to the local ford dealer and see what they think. Everything went smooth until I got to this point in the removal process. Tank was not real heavy to get down. I had siphoned most of the fuel out using a siphon pump from autozone.
Riordan3
Old 09-29-2010, 12:35 PM
Here is it: http://www.ntxtools.com/network-tool...4-p-24603.html
At least, it's less expansive than the one you can find at stores.
Old 09-30-2010, 05:03 PM
Thanks for your effort in finding that tool for me. I've decided to take it to the Ford dealer and have them remove it because I don't want to risk damaging the ring mounted on the tank. The gas tanks believe or not are somewhere between 800 and 1000 dollars from the dealer. I just don't want to take the risk. Could probably get from a junk yard as to opposed to paying all the cash but I don't want to take the risk. I'll let you know how I make out. I talked to the service manager and they have run into this before. He says they break the ring apart that holds the pump in and I'll just have to buy a ring if the new pump doesn't come with a ring. Again thanks for posting that wrench for me.
Riordan3
Old 10-09-2010, 05:43 PM
Installed new fuel pump today and I still believe or not have the same problem.
It will start and idle but as soon as you try to drive it it stalls. If you gas it a few tiimes it stalls. Anyone have any ideas on this one. I'm about ready to take it to a pro to diagnose the problem. So I have replaced the fuel filter, fuel pressure regulator and fuel pump.
Riordan3
Old 10-09-2010, 07:21 PM
Maybe the EGR ports are clogged.
Old 10-09-2010, 09:28 PM
I just went out and unhooked the vacuum line from the EGR valve and plugged the vacuum line with a golf tee. I started it up. When I speed the engine up from idle it will die then come back on. Does not stall. I try to keep a steady speed above idle and it dies then comes back on. Thats the symptom I'm having. Any thoughts on this one? It will idle all day long.
Riordan3
Old 10-09-2010, 10:22 PM
Maybe a bad TPS sensor?
You don't have a CEL illuminated?
Old 10-10-2010, 07:09 AM
No CEL at all. I did check the TPS sensor using a multimeter for resistance. It checked ok resistance wise. I also cleaned the MAF sensor and did a voltage check on it. Voltage changes as throttle is increased, so I assume its ok. It goes from a low voltage to a higher voltage. Any more ideas out there. Keep in mind this is the 3.0 liter V6 not the 3.8 liter.
Riordan3
Old 10-10-2010, 09:01 AM
Of course it's not the MAF, since your idle is very stable. 750 I assume.
maybe a vacuum leak that getting worse when engine is under higher load?
What happens when you place the gear in D, it dies then come back?
What happen when you turn on A/C when it idles?
Old 10-10-2010, 11:52 AM
Well I unplugged the MAF sensor and it runs fine in the open loop mode. I guess I have a bad MAF sensor after all. I drove it 6 miles with no problems. I could not even make it down the street before. I had unplugged the MAF earlier before I changed the fuel pump. I guess its possible I had two problems at the same time. I"ll let everyone know how it runs after I put in the new MAF sensor.
what happens if you just leave the MAF sensor unplugged all the time. Can it do damage? Just curious. I guess one of the side effects is poor mileage.
Riordan3
Old 10-10-2010, 12:56 PM
Yes it can damage if you always drive like that. Cause mixture can be too rich or poor, so unburned fuel can accumulate in cylinder and lead to damage.
