Go Back   Automotive Forums Car Chat > GMC > Jimmy
Old 09-11-2010, 02:21 PM
sbondy sbondy is offline
Exclamation battery wiring
need to find out where negative cables run to from the battery ?
Old 09-11-2010, 04:10 PM
old_master's Avatar
Advisor/Moderator
Re: battery wiring
What year, make, model & engine? Typically the negative cable runs from the battery to the engine block.
You have to know how it works,
to figure out why it doesn't.
Old 09-11-2010, 06:41 PM
Re: battery wiring
Thanks for your reply, but I actually need more info.
There are 3 negative wires--one main wire to the block, I am not sure where the other two wires go?
The vehicle is a '98 GMC Jimmy 4x4 with a 4.3l engine.
Old 09-11-2010, 07:01 PM
old_master's Avatar
Advisor/Moderator
Re: battery wiring
One of the smaller ones goes to body ground: On the radiator support between the battery and the right headlight housing, it's bolted on. The second smaller one goes to the frame below the battery, it also bolts on.
