Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 09-11-2010, 10:07 AM
bhw33191's Avatar
bhw33191 bhw33191 is offline
Send a message via AIM to bhw33191
Is my alternator done for?
Its a new 95A alternator, installed 3 months ago. So i'm making a 6 hour trip from Maine to MA and all of a sudden my subs start cutting out, i look at the volts and they were spiking up to 16 or 17 volts!!! "I unplugged my subs just to be safe." If i kept the RPMs below around 1900, the volts wouldn't spike, i drove the car like this all the way and luckily she made it. But when the volts arent going crazy, its still overcharging at idle around 14.5 volts. I just don't understand this, they reallly mustn't build em like they use to because i put a lot of stress on my stock 78A alt with my stereo system and never had a problem.
'83 Caprice Classic LM1 (truck) 350 swap. about 200HP, 305 ft/lbs..for now.
-- 65,000 original miles --
Old 09-11-2010, 10:55 AM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
Re: Is my alternator done for?
Sounds like the voltage regulator went bye-bye. I remember this happened to me once about 4 years ago, and I was sure I was going to burn out the headlights on my way home from my friend's house ... couldn't understand why they were so bright, looked down at the volt gauge and it was on 18!
Is it a Delphi alternator or aftermarket?
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1!
2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness!
1967 El Camino L79/M20 old school asphalt raper
Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have.
Old 09-11-2010, 03:56 PM
j cAT j cAT is offline
I think I mentioned this to you before. these low amp alternators will not last with high powered noise makers. the current surges will destory the rectifiers. try to locate a larger alternator with an external rectifier mount on the alternator. this will last longer. you do have the large capacitor at the amp input I believe .
Old 09-11-2010, 04:26 PM
caffeineaholic's Avatar
caffeineaholic caffeineaholic is offline
On my 85 I usually read anywhere from 13.5 volts to 14.8 volts. Unless if I'm mistaken, 14.5 volts is normal -- although I don't know if that's bad for the stereo system/subs. I have the 78amp alt. Had a 95amp before and same voltage if I recall correctly.
Just my
1985 Chevy Caprice small-block V8 305ci (5.0L) - 4-Barrel Q-Jet (E4ME) - 700R4 - 115k+ mi. - resonator and A/C components deleted.
Driven in severe weather most of the year (Arizona 100+ degrees during summer heat or in wet weather especially in harsh monsoons). About 30/70 highway/city driving.
Old 09-11-2010, 06:26 PM
Just my
your correct that this is in the normal range 13.5-14.8 volts under normal operation.
if your using more than 70-90amps this voltage will drop below 13.5volts.
if the regulator fails this would go to 18volts. this would then damage the battery plates and may on a newer vehicle damage the PCM.
Old 09-12-2010, 09:45 PM
96capricemgr 96capricemgr is offline
When you guys talk voltage are you talking multimeter readings or factory gauge??? Factory gauges should NOT be trusted for a number but rather watched for a change from normal.
You know on the later b-bodies a 135amp alternator was common so there might even be a factory higher amp solution out there.
96 Caprice Medium Garnet Red
11.56 at 115.9mph naturally aspirated
94 Caprice wagon, rotted out POS
Old 09-13-2010, 07:02 PM
bhw33191's Avatar
I'm using an aftermarket gauge so the readings are fairly precise.
Old 09-13-2010, 07:11 PM
bhw33191's Avatar
May i remind you that the problem is the alt that failed IS (or was) bigger than the factory 78A. I just think its crazy how the 78A never failed because that thing was stressed out just running the stock accessories! (Especially at night with the lights and fan on high).. and now this brand new 95A kicks the bucket at 3 months old. I guess thats what you get for a non-GM product. The guy i got it from specializes in electrical equipment, i even told him i had a big sound system so i'm just surprised he gave me this "premium quality alternator" and not something better.
Old 09-13-2010, 08:28 PM
think about these 2 alternators ? 78 , 95 not much difference.
also who determined what that amp capacity really is on the 95 amp ? under what conditions ?
you need a 140 amp minimum. you also must have the capacitors at the amp input to smooth out the surges.
another factor is heat load. this summer we had record heat .
