Go Back   Automotive Forums Car Chat > Buick > Regal
Old 09-10-2010, 04:59 PM
Saki26 Saki26 is offline
1996 buick regal gransport 3.8L
where is the coolant fan relay switch??
Old 09-11-2010, 02:16 PM
Ruley73's Avatar
Ruley73 Ruley73 is offline
Re: 1996 buick regal gransport 3.8L
If I remember correctly, the cooling fan relays are located in the underhood fuse block on the passenger's side. They are switched on and off per ECM command. There is one engine coolant temp sensor which the ECM uses to determine when to turn the fans on. I believe the engine coolant temp sensor is near the water outlet/thermostat housing in the lower intake manifold on the 3800 Series II.
My rides:
2007 Chevy Equinox LT FWD
2018 Chrysler Pacifica Touring L
"If women don't find you handsome, they should at least find you handy!"
- Steve Smith (Red)
