Old 09-09-2010, 07:31 PM
brocsbar brocsbar is offline
Question escort 2.0 p0352
Hi All I got a 1998 ford escort se 2.0 sohc and it isn't running very well. The only code Im getting is p0352 ign coil b. My solus pro troubleshooter doesn't list the code. I changed plugs wires and coil pack to no avail.. ...any ideas or experiences?? hardly idles. Im going to try the CRK sensor and will post back the results. I'm hoping that it is what gives power to coil.
Old 09-10-2010, 06:23 PM
Re: escort 2.0 p0352
crank sensor didn't help
Old 09-10-2010, 08:50 PM
well i found a bad wire from the coil at the connecter...it had 12v on middle wire and right wire but not left traced it and whooaallaa it was broken and now it runs like a dream.. Hope this helps someone else...with key on 12v middle left and right wire...if u test and no 12v on one of the 3 wires then u know which wire to trace
Old 09-11-2010, 12:34 AM
Davescort97 Davescort97 is offline
Escort guy
Glad you got it fixed. Your solution will be archived and hopefully it will help someone else with a similar problem.
