| Cavalier Problem Diagnosis Got a problem you can't fix? We can help. |
fuel line help
after leaving the fuel filter, were dose the fuel enter the throtle area?
Problem, fuel coming out of filter but making it to engine. car will run as long as i squirt gas into throttle. thanks for any help. rich4
Re: fuel line help
Your model year and trim level/engine code might help. Cavliers have been made for decades, so there are many variations of carbureted, throttle body injection, and port fuel injection. But typically, after the filter the fuel will be routed to the fuel injectors through a feeder pipe. Then the excess fuel will follow the closed loop through a fuel pressure regulator and back to the tank.
Try to perform a fuel pressure test. If you don't see good pressure, the issue could be the regulator or the pump. If pressure is good, then listen to the injector's pattern. It should be constant and even clicking. You can use a long screwdriver or rod up against the injector and your ear to help listen. Or use a finger to feel the injector click. Hope this helps!
Current Garage: 2009 Honda CR-V EX 2006 Mazda 3i 2004 Chevrolet Silverado 2500HD 2003 GMC Envoy XL 2000 Honda ST1100 2000 Pontiac Sunfire Vehicle History: 2003 Pontiac Vibe AWD - 1999 Acura Integra GS - 2004 4.7L Dakota Quad Cab 4x4 - 1996 GMC Jimmy 4wd - 1995 Chevrolet C2500 - 1992 Toyota Camry LE 2.2L - 1992 Chevrolet S10 Ext. Cab 4.3L - 1995 Honda ST1100 - 1980 Yamaha XS400 - 1980 Mercury Bobcat. |
Re: fuel line help
this is for a 96 2.2engine
Re: fuel line help
I know the pump is pupping fuel
pass the filter and so I want to disconect the line at the engine, but I'm not sure which line is the fuel inter line.
Re: fuel line help
Even though you get a signal + clicking sounds from the injector, doesn't mean it's getting a good flow rate.
Re: fuel line help
Follow the line from the fuel filter to the engine. There will usually be a clamp, tubing fitting, or quick disconnect you can undo prior to the feed to the injectors.
