Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 09-09-2010, 07:46 AM
$STEALTH$'s Avatar
$STEALTH$ $STEALTH$ is offline
Eclipse Lover
95 Eclipse RS turns over but no fuel to engine
hey everyone... My car will not start. I have diagnosed part of the problem already. Yesterday morning my car started... i let it warm up for work. Then i come back out to leave and it was dead... car killed on me. Lights and everything were still on. Heater... etc... I tried to start the car again. And i noticed my fuel pump didnt turn on. Later that day i got home from work and tool out the back seat and tested the pump. It worked great. But there is no power getting to it. I took a light tester to the blue black and blue wire for the pump. I got no voltage at all??? What could the problem be? i checked all the fuses. they alll had their arc still in tact. Now the relays i havent got to yet. I dont know which relay is the one.
I noticed this was gonna happen sooner or later because when i would be driving the car. I would watcch the rpm's drop to zero then come back up to normal. Pretty much the car would kill on me then come back again. Please help...
Old 09-09-2010, 09:48 PM
Papa George Papa George is offline
Re: 95 Eclipse RS turns over but no fuel to engine
sounds to me like the fuel pump relay, on my 97 is on the firewall drivers side. there are three relays one of them is the fuel pump relay about 15 bucks at the auto store.
Mine went out last year thats why is say that is what it is. had the same issue your having
Old 09-09-2010, 09:58 PM
danielsatur danielsatur is offline
$2.00 cover @ lkqx!
Old 09-12-2010, 12:43 PM
$STEALTH$'s Avatar
Eclipse Lover
my car only has two of them which one would it be?
Old 09-12-2010, 05:39 PM
UN plug them and check the pin-out (the location of the pins in the plug) if they are the same then swap them and see if the car starts, if it does then go and by one, the replacement will be universal so any will fit.
FYI the fuel pump relay is the same one that controls the coil.
Old 09-13-2010, 07:09 PM
$STEALTH$'s Avatar
Eclipse Lover
I come to find out that my 3rd spark plug wire was barely connected to the coil... I need a new one says the guy at autozone. It was throwing a code to him. And my o2 sensor is throwing a code too
