Old 05-19-2003, 03:55 PM
95_GSX's Avatar
95_GSX 95_GSX is offline
Send a message via Yahoo to 95_GSX
Rim Size?
What are the biggest wheels that can fit a stock 95 GSX?
Old 05-21-2003, 10:50 PM
Zero8985's Avatar
Zero8985 Zero8985 is offline
Send a message via AIM to Zero8985
The biggest that can fit the car is too much for the car to handle. I would suggest 18's with lower profile, but i warn you that will be a bumpy ride. 17's will ride smooth though
Old 05-22-2003, 05:03 PM
95_GSX's Avatar
Size?
Which would handle better 18's with low pro's or 17's with a moderate side wall? My car rides rough anyway so i am not concerned with that. Thanks
Old 05-28-2003, 11:57 PM
FourG63 97GST FourG63 97GST is offline
Send a message via AIM to FourG63 97GST
40 series tires with 18 will handle better in the corners
but 45 series with 17s will be better off the line.
then the 17s will most likely be lighter. light=good
Ill go 17s with 45 series tires (which I have
Old 05-29-2003, 11:57 PM
Spectrum Spectrum is offline
Send a message via ICQ to Spectrum Send a message via AIM to Spectrum
235/45/17 is the biggest I would go. You really need to get the offset right though. Do some research.
Old 06-09-2003, 09:27 PM
Dfreak Dfreak is offline
What do you mean by the offset?
Old 06-09-2003, 09:59 PM
Rims have offsets. Again do some research
Old 06-09-2003, 11:24 PM
Zero8985's Avatar
by offset he means how wide the rim is. the wider the rim, the bigger the offset. When you look at the size of the rim it will say something like 17 X 6.5 or 18 X 7, where the 6.5 and 7 are in inches. If you want better handling, i suggest a lower offset for a wider turn radius without risk of rubbing.
Old 06-10-2003, 12:28 AM
Copy and pasted from www.tires101.com
The offset of a wheel is the distance from the mounting surface of the wheel to the true centerline of the rim. A positive offset means the mounting surface of the wheel is positioned in front of the true centerline of the rim / tire assembly. This in effect brings the tire in to the fender well more. Conversely, a negative offset means the mounting surface of the wheel is behind the true centerline of the rim / tire assembly. This will cause the tire to stick out away from the vehicle.
Old 06-10-2003, 12:55 AM
Zero8985's Avatar
the post above makes my post above that one completely incorrect!
Old 10-16-2003, 07:14 PM
95_GSX's Avatar
alright here is my new question, i am currently on stock rims with 205/55/R16. I would like to get my car handling on rails, so i would like to know what would work better for that 205/35/18 or 205/45/17? both these tire sizes should keep my speedo fairly accurate, correct? thanks for the help. oh and once again ride quality doesnt really matter, it is how it handles that i care about.
Got AWD?
Some people buy super cars, other build them
----Click It, For Mods and Pics----
'95 Mitsubishi Eclipse GSX - For Sale
'05 Volkwagen Golf GLS TDI - My daily driver
'03 Ford Excursion 6.0L PSD 4x4
'13 Ford F150 FX4 SCREW 4x4 3.5L EcoBoost
'08 Buell 1125R
'83 GMC Sierra Classic K2500 4x4 - Future Cummins Swap
Old 12-31-2003, 08:46 PM
95_GSX's Avatar
ignore my previous question, i have done some research and found a wheel that i like, and i am just waiting to here back from the company on the weight of it. but here is my question on fitment, the wheel is sized 17X7 with a 40mm off-set. i would like to wrap a 225/55/R17 tire around it. am i going to have any clearnce problems with my suspension or wheel wells??? thanks for the help, i know the tire questions get old.
Got AWD?
'08 Buell 1125R
Old 12-31-2003, 11:09 PM
BoostedSpyder's Avatar
BoostedSpyder BoostedSpyder is offline
Send a message via MSN to BoostedSpyder Send a message via Yahoo to BoostedSpyder
Re: Rim Size?
i'm getting 19's soon...
Old 01-01-2004, 11:21 PM
kjewer1 kjewer1 is offline
AF - Advisor
Everyone just keep in mind if you ever plan to drag race the car the shorter sidewall will hose your efforts big time. I'm on "50 series" tires and thats pushing it. a 225/55 sounds like a good choice. I believe stock offset is 42mm, so 40 will move the wheel 2mm to the inside, you may hit the suspension. Find out what the offset is on the MAzda Millenia stock wheels, 17x7s. Thats what I run. And with 215/50/17s they just rub on the suspension. If they have a 40mm offset, youre in trouble Etc.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 01-01-2004, 11:23 PM
95_GSX's Avatar
Re: Rim Size?
alright that helps me out alot. i will do some more research. thanks again.
Got AWD?
'08 Buell 1125R
Tire size, rim size, how big is your limit? krackaboy1 Nova 0 05-01-2006 09:57 PM
rim size and fuel urasula Tires and Wheels 4 04-20-2004 08:51 PM
Rim size and weight question- 17x7 rim? cliffud Cosmetics 4 02-13-2002 06:09 PM
Tire and rim size for G20 with stock suspension oakfan Suspension 0 11-26-2001 02:17 AM
Rim Size Width. What is the max... hybridamp Suspension 1 11-21-2001 11:00 AM
