Go Back   Automotive Forums Car Chat > Mercury > Grand Marquis
Old 09-08-2010, 09:24 PM
Blue)(Fusion's Avatar
Blue)(Fusion Blue)(Fusion is offline
Send a message via AIM to Blue)(Fusion Send a message via Yahoo to Blue)(Fusion
Which water pump
2000 Grand Marquis.
The bearings on my water pump have been noisy for about a year now. I think it's time to replace it as the pulley is starting to wobble a bit and is getting noisier.
Is this the water pump I want to replace it with?
http://www.napaonline.com/Search/Det...50046+2046021#
Counterclockwise rotation, NAPA part # WP 58569.
Additionally, when I change the pump I will flush the cooling system. Should I fill with the Zerex G-05 spec (Ford Gold) or the Ford Green coolant? The original fill was the Ford Green. I've been running Prestone for the past year. I want whatever inhibits rust the best and keeps things cool (which I never had a problem with).
2000 Mercury Grand Marquis LS
- 119k / 14.89s @ 92.11MPH [ pictures | videos ]
> Dual Flowmaster Delta 40s / J-Mod / PI Intake Manifold & Cams / Marauder Air Box & 80mm MAF / 3.55 Trac-Lok
> Bumper Tuck / Steeda UD Pulleys / CVPI Zip Tube / Ported & Polished Plenum / BBK 70mm TB
> BOC 93 Octane Tune / Headlight Relay Upgrade / 17mm rear stabilizer bar / Heinous Aluminum Billet Rear Control Arms
> CVPI aluminum driveshaft
