Go Back   Automotive Forums Car Chat > Mitsubishi > Galant
Old 09-08-2010, 12:56 PM
les1 les1 is offline
Changing front brake pads.......
Is it difficult to change fron brake pads on a 2000 Galant 4cyl?
I have done this on other cars years ago are they roughly all the same?
Thanks........
Old 09-08-2010, 08:32 PM
RahX RahX is offline
Re: Changing front brake pads.......
Should be very easy.
Old 09-11-2010, 07:10 AM
Good morning Rhax,
Had a go at the front brake pads today they are a little different to the ones that I have done before. However you need the full caliper off. I couldn't budge the bottom bolt & run the ring spanner a bit maybe not too much. Can you tell me if the size for that nut is a "17 metric" or is it imperial size. One other point how do you remove the retaining clips for the pads?
