Go Back   Automotive Forums .com Car Chat > Chevrolet > Lumina
Old 09-07-2010, 12:51 PM   #1
gene5118
95 Lumina radiator fans
My primary radiator fan will not come on. I have gotten it hot enough, it should turn on. My A/C fan will work but during this 95+ degree summer it would still run tooo hot without the primary fan. Temp sensor replaced, relays test good, jumping relays primary fan will run. Unplug temp sensor and only the a/c fan will run. I am thinking this only leaves wiring or the brainbox. Anyone have any thoughts to add? Its a 3.1 sedan.
gene5118 is offline   Reply With Quote
Old 09-08-2010, 09:10 AM   #2
jeffcoslacker
Lactose the Intolerant
jeffcoslacker's Avatar
Re: 95 Lumina radiator fans
There's two temp sensors...you may not have replaced the one the ECM uses to determine when to start the fan...
You made three mistakes. First, you took the job. Second, you came light. A four man crew for me? F**king insulting. But the worst mistake you made...
...empty gun rack.
jeffcoslacker is offline   Reply With Quote
Old 09-08-2010, 06:15 PM   #3
gene5118
Didn't know there were two sensors, I replaced the one by the thermostat housing. Its threaded into a water jacket. Where is the other one?
