| General Tools Discussions about tools - there are thousands of various tools you can use to work on your car. Do you have the right one for the job? |
Brake Blleeding Tool
Does anyone have an opinion on any of the vacum type brake bleeding pumps. I never seem to have an extra hand when I need to do this.
Re: Brake Blleeding Tool
I use my hand pump to do a rough bleed, but I've come to learn it isn't as good as a foot-on-the-pedal bleed. You can't suck the air out with as much force as the foot pedal method. I also frequently have trouble getting a good seal between the pump tubing and the bleed fitting....always see bubbles and can't tell if it is sucking the air in between the tubing and fitting or through the threads between the fitting and brake cylinder/caliper.
The one-man bleeder systems are better if set up right where you fill a container half full with new fluid, attach tubing to the bleed fitting and immerse the other end into the fluid. Having a second person is better since you can close the fitting after removing all the air and the brake is depressed.
Current Garage: 2009 Honda CR-V EX 2006 Mazda 3i 2004 Chevrolet Silverado 2500HD 2003 GMC Envoy XL 2000 Honda ST1100 2000 Pontiac Sunfire Vehicle History: 2003 Pontiac Vibe AWD - 1999 Acura Integra GS - 2004 4.7L Dakota Quad Cab 4x4 - 1996 GMC Jimmy 4wd - 1995 Chevrolet C2500 - 1992 Toyota Camry LE 2.2L - 1992 Chevrolet S10 Ext. Cab 4.3L - 1995 Honda ST1100 - 1980 Yamaha XS400 - 1980 Mercury Bobcat. |
