Old 09-06-2010, 01:35 PM
polaroman polaroman is offline
engine and power windows die intermittenly
First time here.
1996 Park Avenue 5.8 liter.
First time it happened I'd been running about 20 miles, and the motor shut off. I coasted to shoulder and tried to restart. Engine cranked, but would not stay running. All power windows were dead, Every other electric option still worked.
Tow truck arrived in a half hour, and the driver promptly lowered the power window. Car started and ran fine when I got towed home.
It took a while for the problem to resurface. It had the same to symptoms-no ignition and no power windows. Problem resolved itself in a half hour again.
Any ideas?
Old 09-06-2010, 03:18 PM
96 Park Ave fuses and relays
Does anyone know where or how I can identify what fuses/relays/breakers are behind the wall on the passenger side of the car.
Is there an easy way to remove this panel. I'm trying to find a common between ignition and power windows.
Sometimes when the car's been running a while, both the engine and power windows quit for about half hour, and then all is fine until the next time.
Old 09-06-2010, 05:32 PM
stripe stripe is offline
Re: engine and power windows die intermittenly
Originally Posted by polaroman View Post
First time here.
Any ideas?
Have you checked the battery and charger?
Cheers
Stripe
Old 09-06-2010, 08:20 PM
Smitty's Buick Smitty's Buick is offline
Re: 96 Park Ave fuses and relays
It should be noted in the owner's manual as well as inside the kick panel if I remember correctly. Remove the black plastic panel and drop the glove box to get to the fuse panel. I think there is a schematic diagram attached to the inside of the panel.
Smitty's Buick
Old 09-06-2010, 08:41 PM
danielsatur danielsatur is offline
If owners manual lost, check for one in the salvage yard.
Old 09-06-2010, 10:30 PM
HotZ28's Avatar
HotZ28 HotZ28 is offline
AF Moderator Elite
No need for that, here you go.
BE COURTEOUS: AVOID DUPLICATE POSTS
Do not post the same discussion more than once on a discussion forum or on many forums. Duplicate discussions can be frustrating for other members, especially for those whose time and energy is limited. Weeding through the same discussion in multiple locations can be not only frustrating, but down right annoying. Duplicate discussions will be deleted. Reposting the same message repeatedly can be interpreted as SPAM and could result in the loss of your membership. Also be conscious of your fellow members and avoid making meaningless posts for the sole purpose of increasing your post count.
Tags
fuses , ignition , relays
