Go Back   Automotive Forums Car Chat > Toyota > Cressida
Old 09-06-2010, 12:37 PM
china001 china001 is offline
Red face 1990 Cressida temp gauge, moon roof, and ABS light
Hi:
I own a 1990 Cressida with 131K miles and it runs excellent. I ran into problem with temperture gauge couple weeks ago. Since then it happens four times. The systom of problem is that the needle of temperture gauge shot to highest point, then it dropped down to normal. The car does not have over heat issue. The teperture sensor was replaced four months due to cracked plastic insert.
Please help me to find the problem.
Thanks
Old 09-26-2010, 06:11 AM
rhandwor rhandwor is offline
Originally Posted by china001 View Post
Hi:
Thanks
Pull the temperature switch wire use a piece of copper wire and ground it against the block. With the ignition on the gauge should peg if it doesn't the gauge is bad. Use an ohm meter and ohm the wire between the sending unit and the gauge it may be bad.
Compare with a new sending unit.
Old 10-11-2010, 01:41 AM
AF Enthusiast:
Thank you for your assistant. With the same car, I have found cracked glass in the part of moon roof (sun roof). The crack is about 4 inches long on the corner of glass. Do you have any suggestion for this?
Thanks
Old 10-11-2010, 04:28 AM
AF Enthusiast:
Thanks
Go to a glass shop that sells auto windshields and check if they can get you a new piece of glass.
Old 11-11-2010, 05:04 PM
AF Enthusiast:
Thank you for your assistant. With the same car, I found the Anti-lock indicator light on. What could be cause of this problem?
Thanks
Old 11-18-2010, 10:16 AM
jdmccright's Avatar
jdmccright jdmccright is offline
The RustBuster
Re: 1990 Cressida temp gauge, moon roof, and ABS light
Just FYI for the future, when constructing your thread, please either keep it focused to one problem or summarize it all in the thread title so that others will know at a glance what help you need. I've changed the thread title to reflect the ongoing issues.
With that being said, welcome to AF!
An illuminated ABS light usually means there is a problem with one of the sensors at the wheels or there is a problem in the ABS unit itself. This requires an ABS-capable scanner to read the trouble code, but the wheel sensors and the wiring to/from them are a good start.
Current Garage:
2009 Honda CR-V EX
2006 Mazda 3i
2004 Chevrolet Silverado 2500HD
2003 GMC Envoy XL
2000 Honda ST1100
2000 Pontiac Sunfire
Vehicle History:
2003 Pontiac Vibe AWD - 1999 Acura Integra GS - 2004 4.7L Dakota Quad Cab 4x4 - 1996 GMC Jimmy 4wd - 1995 Chevrolet C2500 - 1992 Toyota Camry LE 2.2L - 1992 Chevrolet S10 Ext. Cab 4.3L - 1995 Honda ST1100 - 1980 Yamaha XS400 - 1980 Mercury Bobcat.
