Go Back   Automotive Forums Car Chat > Toyota > Highlander/Highlander Hybrid/Kluger
Old 09-06-2010, 11:58 AM
Malski1972 Malski1972 is offline
White Smoke just at start up
Hi...maybe someone here can help. My wife and I just bought a used 2003 Highlander Limited 2WD w/3.0 V6 with 94,000 miles. It was very clean and drove like new and has never been in an accident. We noticed the day after we got it home that at start up, there was some whitish smoke from the tailpipe that didn't look normal. It is summertime and 75 degrees outside, so we should see anything. It goes away after about 1 minute, and seems to drive fine. I checked the fluids, and the antifreez and oil sem to be at the correct levels. Can this be due to a gasket leak, a bad PVC valve, or something else I am missing? Has anyone else have this problem with this 3.0 V6? Thanks in advance for your help or advise...Michael
Old 09-08-2010, 07:19 AM
Ivan Hutchins Ivan Hutchins is offline
Re: White Smoke just at start up
Whit smoke is just starting. I am not a mechanic so advising you to go to mechanic urgently.
Old 09-08-2010, 11:27 AM
typesix typesix is offline
Yes, take it to a mechanic for a check. White smoke could mean a head gasket problem, keep checking the coolant level till you get it to a mechanic.
Old 08-21-2011, 12:06 PM
okundalaye kayode okundalaye kayode is offline
Am kayode by name, take ur car to garage and tell d technician to check d A/F sensor, and Air flowmeter sensor as well.
