Old 09-04-2010, 06:17 PM
Jmrec100's Avatar
Jmrec100 Jmrec100 is offline
Passenger side Half Axle
Have a problem. I whacked the passenger side half axle with it's short spline section into the trans. Whacked the short spline section and I thought it seated. Now when I went to check the fluid, I see this. I'm going to remove the wheel, calipers, strut assy, etc and then try to whack it in all the way attached. Any other ideas. Thanks.
Old 09-04-2010, 06:55 PM
maxwedge maxwedge is offline
A990 racer
Re: Passenger side Half Axle
Check the lock ring, pull it back out first.
Old 09-04-2010, 07:51 PM
Jmrec100's Avatar
Is it supposed to be recessed? I looked at my old picture of trying to pull that shaft out - passenger side. See the picture. It is the old trans with the same spline. I pulled this spline out to put in my new trans. It looks like it sticks out too. Can anyone take a picture of their drive axles as it connects to the trans. Both sides. I want to be sure it is seated right. I have finished swapping motor and trans. Just this last step. Is there a cover I am forgetting? Can't believe that it would be exposed like this?
Also, with the wheels in the air , the trans does Not seem to lock the wheels? It shifts thru all the gears (engine off) but in park the wheels rotate. Is there an adjustment?
I think its mechanical lock, but If its low on trans fluid, would it cause this free wheeling in park?
File Type: jpg Old trans. Spline sticks out P1020237.jpg (99.6 KB, 3 views)
