Go Back   Automotive Forums Car Chat > Honda > JDM Motor & Parts info/chat
JDM Motor & Parts info/chat Discussions on Mugen, Spoon etc. Plus, info on motor swaps (b18 's, b16's h22's etc) and other JDM info!
Old 09-04-2010, 03:28 AM
summernightdrive summernightdrive is offline
Engine Bogging down!!
Ok so today I went to a self car wash to wash my car. While there I cleaned my engine bay and put "engine restore" additive into my oil. When leaving my car (I have a 1991 si hatch with a B16a) started right up. Then about one mile down the road I felt a large amount of power loss.
When I got home I immediately checked for water in the intake and did not notice any (I cleaned it, dried it, and re oiled it anyways). Then I thought that maybe the additive messed something up so i did an oil change as well.
The problem still persists and am afraid to drive my car. It does not bog down until about 3 min into warm up, but then it stays... Do you think that while washing my engine I messed something up??
I do know, that my car needs a new fuel pump, but i just think it would be a large coincidence that it starts acting up after I messed with my car a bit...Just let me know what you think!! Thanks
Old 09-04-2010, 11:09 PM
Re: Engine Bogging down!!
Ok...so there was water in the spark plug ports...all is well now
Old 09-04-2010, 11:24 PM
danielsatur danielsatur is offline
Try drying Engine with a leaf blower!
Use a hair dryer on COP's and electrical connectors.
Old 06-25-2016, 06:33 PM
jasonnastley jasonnastley is offline
Water in the spark plug is causing this.
Old 06-26-2016, 09:54 PM
MikeCStig MikeCStig is offline
I'm not sure whether you're doing it this way or not, but just in case you're not, I'll share a tip. When you wash out the engine bay, you should do it with the engine warmed up and running, and leave it running for a bit after you're done. That way the heat will cause the moisture to evaporate quickly rather than seeping into crucial parts of the engine and causing problems.
"Ok, systems check; the battery is discharging, the oil temperature is very high, the oil pressure is very low, the engine temperature is off the end of the scale, I'm running out of petrol... but the clock is correct!"
-James May, in an old, worn out Lamborghini purchased for less than £10,000.
