Go Back   Automotive Forums Car Chat > Kia > Sedona | Carnival II
Old 09-04-2010, 01:17 AM
famlycar famlycar is offline
Sedona Sliding Door Problem
Is the passenger side sliding door supposed to automatically open from the inside by a switch instead of manually?
Old 09-05-2010, 07:01 PM
RahX RahX is offline
Re: Sedona Sliding Door Problem
The unlatch motor will go bad at some point. It will not open by switch or remote automatically if that happens. If you use either inside/outside handle to unlatch it, it will work normally. The same goes for closing. You can buy the motor by itself, it is a little guy. If you haven't ever had the door panel off of a sliding door, it can be a pain and the door controller that houses the motor is hard to get out if you haven't done one before either.
