Old 09-03-2010, 09:42 PM
hunter4ever12 hunter4ever12 is offline
Strange clicking noise inside cab when turning right
Whenever i turn right in my 92 k1500 it makes a strange rattling/clicking noise coming from somewhere between the steering column and the drivers door i cant figure out the exact source or even what it could be. It does tick slower when im going slow and faster and louder when i am going fast and when sitting still it doesnt do it at all. But i am possitive its coming from inside the cab so im baffled
Old 09-04-2010, 11:50 PM
corsair-pilot corsair-pilot is offline
Re: Strange clicking noise inside cab when turning right
Hi.
This is just something to ponder.
INTERMITTENT STEERING COLUMN SNAP OR CLINK NOISE WHEN TURN. #56-32-02B
REVISION: 04/11/96
THIS BULLETIN IS BEING REVISED TO ADD THE PASSENGER CARS AND UPDATE PARTS INFORMATION. PLEASE DISCARD CORPORATE BULLETIN NUMBER 56-32-02 (SECTION 3 - STEERING/SUSPENSION). __________________________________________________ ____________________ REVISION: 09/12/97
THIS BULLETIN IS BEING REVISED TO CORRECT THE TRUCK MODELS AND PART NUMBER DESCRIPTIONS. PLEASE DISCARD CORPORATE BULLETIN NUMBER 56-32-02A, DATED APRIL, 1996 (SECTION 3 - STEERING/SUSPENSION). __________________________________________________ ____________________
SUBJECT: INTERMITTENT STEERING COLUMN SNAP OR CLICK NOISE WHEN TURNING (INSTALL NEW UPPER BEARING SPRING)
MODELS: 1994-96 BUICK CENTURY, LASABRE, PARK AVENUE, REGAL, ROADMASTER 1995-96 BUICK RIVIERA 1994-96 CADILLAC CONCOURS, DEVILLE, ELDORADO, FLEETWOOD, SEVILLE 1994-96 CHEVROLET CAMARO, CAPRICE, CORVETTE, LUMINA, LUMINA APV 1995-96 CHEVROLET MONTE CARLO 1994-96 OLDSMOBILE CUTLASS CIERA, CUTLASS SUPREME, EIGHTY EIGHT, NINETY EIGHT, SILHOUETTE 1995-96 OLDSMOBILE AURORA 1994-96 PONTIAC BONNEVILLE, FIREBIRD, GRAND PRIX, TRANS SPORT WITH TILT STEERING COLUMNS
1995-96 CHEVROLET AND GMC C/K, S/T TRUCK 1994-96 CHEVROLET AND GMC M/L AND G VANS WITH TILT STEERING COLUMNS
CONDITION:
SOME OWNERS MAY COMMENT ON AN INTERMITTENT STEERING COLUMN SNAP OR CLICK NOISE WHILE TURNING. THE SNAPPING OR CLICKING MAY ALSO BE FELT IN THE STEERING WHEEL.
CAUSE:
THE UPPER BEARING RACE SEAT MAY, UNDER SOME TURNING CONDITIONS, MOVE IN AN AXIAL DIRECTION ALONG THE UPPER STEERING SHAFT. THE NOISE IS A RESULT OF THE INNER RACE SEAT HANGING UP ON THE SHAFT AND THEN SUDDENLY RELEASING CAUSING A SNAPPING OR CLICKING NOISE.
CORRECTION:
A NEW UPPER BEARING SPRING WITH INCREASED STIFFNESS HAS BEEN DEVELOPED AND SHOULD BE INSTALLED IN THE STEERING COLUMN. THE NEW SPRING WILL INCREASE THE PRELOAD BETWEEN THE UPPER BEARING INNER RACE SEAT AND THE UPPER STEERING SHAFT. TO ACCOMMODATE THE NEW SPRING WITH INCREASED STIFFNESS, THE CANCEL CAM WILL ALSO NEED TO BE REPLACED. THE NEW SPRING AND CANCEL CAM, ALONG WITH A RETAINER RING AND AN UPPER BEARING INNER RACE SEAT ARE INCLUDED IN THE PARTS KIT LISTED BELOW.
SERVICE PROCEDURE:
FOLLOW THE INSTRUCTIONS GIVEN IN SECTION 3F5 OF THE APPROPRIATE SERVICE MANUAL AND THOSE CONTAINED IN KIT. BE SURE TO USE ALL PARTS SUPPLIED IN THE SERVICE KIT.
PARTS INFORMATION:
PART NUMBER DESCRIPTION =========== ===========
26059701 1994-96 A/B/C/D/E/F/H/K/U/W 26059701 1994-95 M/L/G VANS 26059702 1995-96 BUICK "G" 26059703 1995-96 OLDSMOBILE "G" 26059704 1995-96 C/K, S/T TRUCK 26059704 1996 M/L/G VANS (BOTH STYLES OF G VAN) 26059705 1994-96 "Y"
PARTS ARE CURRENTLY AVAILABLE FROM GMSPO
WARRANTY INFORMATION:
FOR VEHICLES REPAIRED UNDER WARRANTY, USE:
LABOR OPERATION LABOR NUMBER DESCRIPTION TIME =============== =========== =====
E7310 A/B/C/D/E/F/H/K/ USE PUBLISHED W/Y CARS, M/L/G/U VANS LABOR TIME. AND C/K, S/T TRUCKS
E7321 G-CAR USE PUBLISHED LABOR TIME.
FIGURES: 00 ATTACHMENTS: 00
GENERAL MOTORS BULLETINS ARE INTENDED FOR USE BY PROFESSIONAL TECHNICIANS, NOT A "DO-IT-YOURSELFER". THEY ARE WRITTEN TO INFORM THOSE TECHNICIANS OF CONDITIONS THAT MAY OCCUR ON SOME VEHICLES, OR TO PROVIDE INFORMATION THAT COULD ASSIST IN THE PROPER SERVICE OF A VEHICLE. PROPERLY TRAINED TECHNICIANS HAVE THE EQUIPMENT, TOOLS, SAFETY INSTRUCTIONS AND KNOW-HOW TO DO A JOB PROPERLY AND SAFELY. IF A CONDITION IS DESCRIBED, DO NOT ASSUME THAT THE BULLETIN APPLIES TO YOUR VEHICLE, OR THAT YOUR VEHICLE WILL HAVE THAT CONDITION. SEE A GENERAL MOTORS DEALER SERVICING YOUR BRAND OF GENERAL MOTORS VEHICLE FOR INFORMATION ON WHETHER YOUR VEHICLE MAY BENEFIT FROM THE INFORMATION.
COPYRIGHT 1997 GENERAL MOTORS CORPORATION. ALL RIGHTS RESERVED.
© Copyright General Motors Corporation. All Rights Reserved.
Document ID # 502800
