Go Back   Automotive Forums Car Chat > Dodge > General Discussion
Old 09-03-2010, 09:05 PM
himie298 himie298 is offline
Exclamation 1977 d200 clutch problem
I've have just replaced the clutch in a 77 D200 full time four wheel drive. The problem now is in order to get the clutch to release I have to get the through out bearing up tight. when I looked at the disk as the clutch was released the disk appears to be expanding (getting wider). What happing here? was it a cheap clutch and I've popped the rivits? I know the throughout bearing will wear out soon the way I have it adjusted. Any thoughts?
thanks
Jim
Old 09-10-2010, 07:44 PM
mastertech1964 mastertech1964 is offline
Re: 1977 d200 clutch problem
if you had popped the rivets the clutch material would have come untogether in a big hurry. what shape is the bushing in the clutch pedal assy in ? a bad bushing can cause to be in capable of having enough throw to fully disengage the clutch. just throwing some ideas out there
