Old 05-18-2003, 07:57 PM
Integra14's Avatar
Integra14 Integra14 is offline
Send a message via AIM to Integra14
quick little question, not answered clear in FAQ
might need to add:
After Painting, how long to wait, until clearcoat?
Old 05-18-2003, 08:16 PM
daggerlee's Avatar
depends on the type of paint and type of clearcoat
Dan
Old 05-19-2003, 02:40 AM
008's Avatar
008 008 is offline
Follow the Laquer, Enamel, Acrylic rule as described in the FAQ. Now with that in mind, there are several ways of doing it.
If the clear is the same type as the paint, you can either shoot clear immediately after the final color coat or wait until the final color coat cures (up to 2 weeks) before shooting clear. If you shoot clear right away, the clear and color coat will gas out and cure together; fine. If you don't shoot it right away and put clear on before the color coat has cured, the clear will be ruined as the bottom layer tries to gas out.
For mismatched paints e.g. enamel color covered with acrylic clear, you must let the color coat fully cure.
For best results use the same type, preferably the same brand. Boyd's clear over Boyd's enamel, for example.
You can even slowly mix clear into your paint as you apply the final color coats. Let's say you plan on putting 10 coats of paint (who really counts these things?). On coat #8, add a bit of clear to it. On #9 even more clear. Coat #10 could use a lot of clear, say 75% clear to 25% paint. Then follow up with the pure clear coats. Only do this with same type/brand paints/clears and make sure they are indeed the same type!
As a side note, pearl colors are almost always duller than solid colors so a clear coat is usually a necessity. Don't buy a pearl color without picking up a bottle (or can) of clear to go on top of it. Otherwise you'll go nuts color sanding and polishing it and wondering why it isn't getting shiny.
r
Old 05-19-2003, 01:56 PM
Integra14's Avatar
whoops, sorry, i used Tamiya Black spray Laquer
and Tamiya Clear coat..
so i guess ill wait it out.. 2 wks
Old 05-19-2003, 03:11 PM
fullbloodchop01's Avatar
fullbloodchop01 fullbloodchop01 is offline
Send a message via AIM to fullbloodchop01
008:
when u say immediatley, do u mean, once u spray the last color coat, to go grab the clear and spray it? like when th paint is still wet?
Rui
(modeling) = Click Here
Old 05-19-2003, 03:26 PM
daggerlee's Avatar
Tamiya clears can be sprayed 30-60 minutes after the final color coat or 30 days after the final color coat.
Dan
Old 05-19-2003, 04:07 PM
stump's Avatar
stump stump is offline
Send a message via MSN to stump
Thumbs up
Thanks guys, I wasn't 100% clear on that either..(no pun intended)
Old 05-19-2003, 05:28 PM
008's Avatar
008 008 is offline
Originally posted by fullbloodchop01
008:
Well, not that fast but yes immediately after the color coat. Give it a few minutes to "flash", which is about the time it'll take you to quickly clean your airbrush, switch color bottles, or shake the rattle can. Basically you don't want the paint to start curing before you put on another wet coat or the drying times will be different. It depends on the solvent you used to thin the paint. Some solvents will flash faster than others. A paint has "flashed" when it won't stick to your finger, but don't test it that way.
Old 05-19-2003, 08:21 PM
Integra14's Avatar
damn, if i only knew.... i could paint 5 mins after..
AHH now i have to wait like 3 wks?
Old 05-19-2003, 09:37 PM
bah humbug's Avatar
IMO Who cares? Maybe it is a mistake what I do.
I just clear whenever I want to. Nothing bad has happened to me b4.
I say go right ahead. I think shorty cleared his JDM civic the day after and nothing happened to him.
The only thing I make sure when I clear is that the the company who makes the paint I used is the company I will be using for the clear.
Did that make sense?
Old 05-20-2003, 12:55 AM
Ghost_9418's Avatar
Ghost_9418 Ghost_9418 is offline
Ive sprayed Tamiya clear on a few after painting with tamiya paint and nothing bad happened. I would listen to everyone else though, they're a lot more experienced than me.
Ryan
If your new to the AF modeling forum please read this : AF modeling FAQ
Current Project:
Tamiya Porsche Boxster Special Edition
