Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Suburban
Old 09-02-2010, 11:01 PM
miked79928 miked79928 is offline
Tiny Light Bulbs
Does anyone know where I can purchase the tiny light bulbs that go into the door lock switches and the likes? This would be for a '99 Sub. I have searched high and low and have not been able to find them.
Old 09-03-2010, 08:25 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: Tiny Light Bulbs
GM parts department or your local parts place.
Sometimes it helps to remove the bulb and find the no on it.
MT
Old 09-03-2010, 08:10 PM
j cAT j cAT is offline
radio shack has some of these small lamps.
Old 09-04-2010, 09:58 AM
Blue Bowtie's Avatar
Registered Offender
GM Parts will be useless. They will gladly sell you an entire new assembly with the lamp in it.
Check with your local electronics supplier. If they can't help, check MY local electronics supplier:
http://www.jaytronics.com/
Or check online at Digi-Key, Mouser, or of a number of suppliers.
Old 09-13-2010, 10:31 AM
jdmccright's Avatar
jdmccright jdmccright is offline
The RustBuster
I've got to replace the ones in my '95's armrests. I had bought some mini LED bulbs from superbrightleds some time back...some NEO3-x and NEO5-x sizes. But they ended up being too big. I think a NEO4-x bulb might work for the larger size base, but haven't found one small enough to fit the smaller of the two needed on the driver's arm console. Since then I've been too busy fixing/restoring other stuff on it. But I have read that the tiny bulbs are available at Radio Shack as mentioned.
Personally, I'm waiting to find time to search for small enough LEDs to replace them with...just not high on my priority list. Let us know if you find them, regular or LED. Good luck!
Current Garage:
2009 Honda CR-V EX
2006 Mazda 3i
2004 Chevrolet Silverado 2500HD
2003 GMC Envoy XL
2000 Honda ST1100
2000 Pontiac Sunfire
Vehicle History:
2003 Pontiac Vibe AWD - 1999 Acura Integra GS - 2004 4.7L Dakota Quad Cab 4x4 - 1996 GMC Jimmy 4wd - 1995 Chevrolet C2500 - 1992 Toyota Camry LE 2.2L - 1992 Chevrolet S10 Ext. Cab 4.3L - 1995 Honda ST1100 - 1980 Yamaha XS400 - 1980 Mercury Bobcat.
