Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Suburban
Old 09-02-2010, 10:36 PM
Cusser's Avatar
Cusser Cusser is offline
Pressures for 20-inch tires
Just picked up a 2005 (OK, Yukon XL Denali), had factory option 20-inch wheels tires (285/55R20). Door jamb doesn't have anything exept for 16/17 inch wheels tires, which it lists at 30 psi. Anybody know what pressures to use for the 20 inch?? Owner's manual doesn't help either.
Old 09-03-2010, 08:27 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: Pressures for 20-inch tires
Look on the tire in the fine print.
They usually have tire pressure on them.
MT
Old 09-03-2010, 10:15 AM
Cusser's Avatar
I believe that's the tire MAXIMUM pressure.
Old 09-03-2010, 08:07 PM
j cAT j cAT is offline
THE MAX PRESSURE IS ON THE TIRE . this is a guide so you don't over inflate. now how you install the correct pressure is more difficult..with the pressure at about 10psi below the max pressure with a piece of chaulk make a line across the tread face. then on smooth flat pavement drive several feet with the wheels straight . now see how the chaulk has worn off the tread...if the middle is only worn still too much pressure...if its gone to the tread edges add 2 psi more pressure and repeat...
pressures with this type vehicle , should be just a few psi more in the front.
you want all tire treads to have contact with the road surface . this will give max life with min tire damage and lower heat.
Old 09-07-2010, 09:27 PM
laxman21's Avatar
laxman21 laxman21 is offline
THat's what I do regardless of what the door sticker says.
'92 s-10 4x4 EC p/u
'99 Blazer LT
'99 Suburban LT
