Go Back   Automotive Forums Car Chat > Nissan > Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35
Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 Excellent platform and the good ol' VQ30DE and VQ35DE engines.
Old 05-18-2003, 11:08 AM
bk2kmax's Avatar
bk2kmax bk2kmax is offline
Heard of this? Sorry but it's long
SLAM AIR Induction
JMS Products Inc. Slam Air Induction can be installed on virtually every type and make of vehicle for proven performance gains coupled with a 20-30% increase in gas mileage. JMS Products Inc. Slam Air Induction is designed for use on many naturally aspirated applications and is designed to be used on Supercharged and Turbo cars. The purpose of using Slam Air Induction on cars with traditional forced induction is to increase overall efficiency and to reduce lag commonly experienced on Centrifugal Superchargers and Turbos. Roots Blowers will operate with even greater efficiency and produce higher end torque. Further developments will continue as we test 1HP motors. Coming soon are ultra high power units with custom inverters with specially designed blowers that will produce 6-8PSI. 6-8PSI on an electrically driven system will rival belt driven blowers making 8-10PSI since electrically driven units do not take HP to make HP.
Following are 3-29-03 Dyno testing results without tuning of air/fuel with the 7.5 amp AC motors. We will be upgrading to 12 amp AC motors with a more aggressive impeller and an in house developed blower housing that will provide a 35-50% gain in output. We will be also conducting track testing as dyno results only show power gains on paper and do not account for the overall increase in performance and Fuel economy that one will experience. We will also be testing this system with direct Nitrous into the primary blower as we believe the blowers will deliver optimal atomization of the Nitrous coupled with forced induction to deliver a 25% increase in power without increasing cylinder pressure vs just using a larger shot of nitrous to make power.
Red: bridged Slam Air 4th gear pull
Blue: Stock 4th gear pull
Green: Stock 3rd gear pull
92 5.0LX GT 40 heads, Cobra upper/lower, shorty headers, bassani X, 70mm Throttle body, K&N filter in stock air box, E303 cam, ProM MAF.
gain of 10RWHP and 16Ftlbs RWTQ without tune (Run 1 was 3rd gear pull, Run 2 was 4th gear and Run 3 was with the Slam Air Induction. With a tune we are expecting a solid 10 RWHP and 16 Ftlbs RWTQ across the entire RPM band.
SLAM AIR makes almost 20 HP and 20 Ftlbs TQ at the wheels on a Turbo car maxxed out running 15PSI. Why? Quicker spooling and increased overall efficiency..
Red: Turbo only
Blue: bridged Slam Air before Turbo
95 Acura Integra Turbo forged internals, full exhaust running 15 PSI boost, open cone filter.
gain of 16WHP and 16Ftlbs WTQ without tune. Notice the Slam Air reducing turbo lag and optimizing efficiency of the turbo at full boost. We were pleased to see the unexpected power gain at full boost and were very pleased to see the significant decrease in lag coupled with increased HP and TQ throughout the entire RPM band.
With the upgraded blowers we are expecting a solid gain of 24 WHP and 24 Ftlbs WTQ and an even greater reduction in turbo lag.
02 Nissan Maxima Dual Overhead Cam Variable Timing 3.5 ltr
Stock: 198whp 214 wtq
Single Slam: 213.5whp 228wtq
Double Slam: 215whp 238wtq
@ Dyno Testing will continue for 03 Cobra, Corvette, Eclipse 15psi turbo, LT1 T/A and 454 big block with the upgraded blowers that will be ready over the next few days.
Investors are Welcome
PreOrder and save 10%
Color coded Blower Units available. Choose from Red, Blue, Green, Black, and Silver.
Single Slam $495.95, $750 w/ ProM Precal. MAF, $950 w/ ProM Tunable MAF.
Not a supercharger, not a turbo, but an electrically driven blower unit that maximizes intake CFM with cool-stable fresh air.
Kit: Single Centrifugal Charger with high flow filter, mounting brackets, tubing, wiring activation switch, Cobra Inverter and instructions. Also available with a precalibrated MAF sensor from ProM. Choose from many great precalibrated ProM high flow meters as well as the new Tunable Univer from ProM. Gains 5-10 HP and 10-20 Ftlbs at the wheels with a 20% increase in gas mileage on 4Cyl, 6Cyl and most small block 8Cyl applications.
140Mph 600 CFM Unit
Double Slam $750, $985 w/ ProM Precal. MAF, $1185 w/ Tunable ProM MAF.
Not a supercharger, not a turbo, but an electrically driven twin blower unit that maximizes intake CFM with cool--stable fresh air.
Kit: Twin Centrifugal Chargers with high flow filter, mounting brackets, tubing, wiring, activation switch, Cobra Inverter and instructions. Also available with a precalibrated MAF sensor from ProM. Choose from many great precalibrated ProM high flow meters as well as the new Tunable Univer from ProM. Ideal for high CFM applications i.e. big block, turbo, and supercharged engines. Gains 10-20 HP and 10-30 Ftlbs at the wheels with a 20-30% increase in gas mileage on 4Cyl, 6Cyl and most small block 8Cyl applications.
200+Mph 1200 CFM
This system is designed for the ultimate reliability and with the features of the Cobra Inverter, your electrical system will not even know it is running. In addition to the Cobra Inverters many benefits, it also acts as a gatekeeper in that current is monitored and controlled. Unlike direct 12 Volt units, this system will allow greater output and any load on the motors due to back pressure will not cause a current surge on your electrical system.
Applications to be tested: N/A and Turbo 4,6,8 Cyl., Roots/Centrifugal Supercharged 8Cyl, 4.6 N/A, 4.6 Nitrous, Worked N/A 4.6 (GT/Cobra), 5.0 N/A, 5.0 Nitrous, Worked 5.0 N/A, 347 Stroker N/A, supercharged 347 Stroker, 347 Stroker Nitrous, V10 Viper, Worked V10 Viper N/A, V10 Viper Nitrous, LT1 N/A, LS1 N/A, LS1 Nitrous, Worked LS1 N/A, LS4 N/A, LS4 Nitrous, Worked LS4 N/A......
Has anyone tried this and if so does it work?
By the way, it should read bk2k3Max, not bk2kmax.
Old 05-18-2003, 01:04 PM
Pick Pick is offline
Old 05-18-2003, 02:18 PM
Maximadave's Avatar
Maximadave Maximadave is offline
Send a message via Yahoo to Maximadave
too new maybe
2002 Nissan Maxima SE
6-Speed Manual
Majestic Blue
Internet Manager @ Car Buy Choice, Inc.
Buy Your Next Car At Internet Wholesale
www.carbuychoice.com
(800) 290-0660
Old 05-18-2003, 05:56 PM
MaximusGTR's Avatar
MaximusGTR MaximusGTR is offline
Originally posted by Maximadave
too new maybe
Then be the first
Hey BK2 I never heard of that but it sounds interesting
"SHIFT_"
Old 05-18-2003, 06:57 PM
Paonessa Paonessa is offline
i think i'll stick with my tornado fuel saver. they give the same promises and i know first hand that it really works
Old 05-18-2003, 07:30 PM
Old 05-19-2003, 10:55 AM
bk2kmax's Avatar
Originally posted by MaximusGTR
Then be the first
I thought about being the first but I wanted to see if someone else here has already either heard about it or did it to their car first.
I'll admit it does sound interesting and the dyno results are pretty accurate plus it comes from a good website source.
Who knows maybe I'll decide to try it later on after I see more results or someone starts to bragg about what it has done for their car.
Old 05-19-2003, 11:13 AM
bk2kmax's Avatar
Originally posted by Pick
I feel you on that Pick but I warned you first.
Old 05-19-2003, 05:05 PM
That's cool man, it is worth a lookie intooie.
Old 05-20-2003, 01:50 AM
deadmaninc deadmaninc is offline
For what year Max is it? You think it will work on the 04 Max or the G35?
Old 05-20-2003, 05:52 PM
bk2kmax's Avatar
According to the info I posted it was tested on an 03 Max but that doesn't mean that is the only year that they offer it for on our Maxs.
Go to their website and see if you can find a contact to e-mail and ask about if they offer it to other years in the Max line up and let us know.
Old 08-03-2003, 03:00 AM
EPVQ30's Avatar
EPVQ30 EPVQ30 is offline
bk. it is taking me a couple of weeks to finish this thread.. what is going on againg?.. i'm sorry.
SHIFT_99 SE-L 3 pedals
Old 08-03-2003, 05:14 PM
bk2kmax's Avatar
It's not my fault dawg, I didn't invent the wheel I just posted the info on this, I even tried to warn everyone on the title of the thread that it was long.
I'm sorry, but I had to share this! L-Spec Off-Topic 6 10-13-2006 08:29 PM
Sorry guys but it's not a drifter..... jswillmon Remote Control Cars 5 10-19-2004 03:11 PM
lmao, i'm sorry but i have to tell this one: vr4 vs 200sx youngvr4 Street Racing 34 05-28-2004 02:01 PM
