Go Back   Automotive Forums Car Chat > Racing > Formula-One
Old 05-18-2003, 07:25 AM
ales's Avatar
ales ales is offline
Forza Schumacher
Tyre warmers
Any idea what the tempertature is that the tyre warmers warm the tyres up to?
Alex
Old 05-19-2003, 08:50 AM
crayzayjay's Avatar
crayzayjay crayzayjay is offline
CFA
For sportsbikes, i found this, so i cant imagine its hugely different for F1. I'd say upwards of 80 degrees celsius
It takes a long time to heat tires so they will function properly by riding the bike. Compound Tires like Racing Slicks and Treaded Road Tyres (not including Full Wet Racing Tires or Trials type tires), become sticky when they reach 'Operating Temperature'. Operating Temperature usually ranges between 85 - 100 degrees Celcius (185 - 212 degrees Fahrenheit). This temperature is reached due to the tire working on the road / track surface or by being heated close to 'Operating Temperature' using a Tire Warmer.
Until tires are 'up to temperature' they will be inflexable, have a hard surface and a reduced contact patch, they lack grip and sliding is the result. Depending on track temperature and the weather, it actually takes 4 - 6 laps to get tyres to 'Operating Temperature'. That's 4 - 6 laps of less than optimum traction, less confidence and greater risk. In some cases, that's the whole race or over half a Track Ride Day Session.
A 'Good' Tire Warmer will heat tires up to a temperature just short of 'Operating Temperature'. Too low a temperature and the tires will 'Cold Tear' too high and the tires will harden and go off. We deliberately say 'Good' Tire Warmers because most Tire Warmers actually fail do the job right.
Longer Tire Life.
When a tire starts out cold and is worked on the road / track surface the temperature rises, as the temperature rises the surface rubber is removed at a faster rate than when the tire is up to operating temperature. The discarded surface rubber forms little balls at the working edge. This Cold Tearing or Cold Shreading reduces the life of the tire and is avoided when using a Tire Warmer that pre-heats the tire to the correct opperating temperature.
Better Starts.
With grip, feel and feedback available, the rider can enter turn one with the confidence that when they lean the bike into the turn the front will stick and the rear will grip. When the front sticks, the bike will turn and the rider will roll the throttle on. When the rear grips, the bike will drive out of the corner and the rider has put his or her competition behind them when it is easiest to do so. Even if you leave the Pits with tyres heated by Tire Warmers, there is no guarantee that you will have hot tyres at the start line. Our research shows that tires loose temperature as soon as the Warmers are removed. As you ride the gridding or sighting lap, tires are being made colder with Track Contact, no ammount of weaving can compensate. In the end, depending on the Tire Warmers you have used, they have been of little, if any benefit to you.
Through extensive testing and by working with many riders, Sportsbike has developed a design of Tire Warmer that considerably reduces the rate of cooling and enables a tyre to be at a higher temperature at the start line. Sportsbike Tire Warmers are designed to help tires to be hotter in turn one, the rest is up to the rider.
Confidence.
Rider Confidence in the Machine is vitally important. Confidence is psycological and is the attitude of the rider to the way he or she rides the bike. Confidence is however influenced by the level of grip available, the ability to turn the bike, accelorate the Machine progressivly and control the bike with ease. Without these influences being positive and supporting the rider, the Rider's Confidence is lessened or at least distracted.
Without Confidence the rider is often just trying to survive riding the bike. The rider is tense, holds the controlls too tightly, uses stressed and 'jirky' imputs to keep control and is not smooth. If this does not sound familier, it is possible you may not be aware of what is going on when you ride as your attention is focused on suvival.
Rider Confidence in the Machine is what Suspension Set-up is all about and you know how much importance is placed on having the 'right Suspension Set-up'. Rider Confidence is also one of the main reasons Tire Warmers are essential. Tire Warmers prepare the tires so that the rider can go out hard and ride with confidence and control, in racing terms if you start out faster, you will end up faster.
Old 05-19-2003, 08:51 AM
crayzayjay's Avatar
CFA
hehe... i found this Q&A a minute later, an interview with Bridgestone technical manager Hisao Suganuma
Q: How hot do the tyre warmers make the tyres?
A: Normally the blanket temperature is set by the team, normally about 70 or 80 degrees C for each tyre.
i was pretty close!!!
and that is damn hot! :flash:
Old 05-19-2003, 08:58 AM
ales's Avatar
Forza Schumacher
Thumbs up
Cheers! Thanks for the info.
Old 05-19-2003, 02:55 PM
Guido Guido is offline
I thought it was between 80 and 90° C. Yep that's very hot.
Old 05-19-2003, 03:40 PM
ales's Avatar
Forza Schumacher
To put things into perspective- that's pretty much the temperature of an engine of a normal car ... all I can say is WOW! And if I understand correctly, the tyres get even hotter during the race?
Old 05-20-2003, 03:09 AM
Which could explain the blistering during and after
Old 05-22-2003, 10:00 AM
kaoru-tochiro's Avatar
kaoru-tochiro kaoru-tochiro is offline
Banned
Two years ago I went to a Trans Am race and the #7 Valvoline blew a tire, so I stole the slick and I brought it home and then the tire was still soft for the next 2 days, I mean if I put it on the ground it could pick up pebbles from its stickyness. if I touch it now it feels hard like hardened tar.
Tyre warmers geronimo77 Car Modeling 10 03-08-2008 08:58 AM
Bottle Warmer Install???!!! MD99SiR Forced Induction 0 02-21-2002 11:02 AM
