Go Back   Automotive Forums Car Chat > Engineering/ Technical > Tires and Wheels
Old 05-17-2003, 08:32 PM
Jfo Jfo is offline
tire size and ride height ? on civic
Ok in the front my car has 185/65/14 and the back it has 195/60/14 and there is a 1 inch ride height between the front and back..i have measured the fenders to ground and also the gaps and tires...and they are each 1 inch difference so my question is if i put got rid of the 190s and put some 185/65/14 on the back would it level out my car and get ride of the 1 inch difference.thanks
Old 05-20-2003, 03:20 AM
BullShifter's Avatar
185/65R14
DIAMETER: 23.5" SECTION WIDTH: 7.3" SIDEWALL HEIGHT: 4.7"
MINIMUM RIM WIDTH: 5.0" MAXIMUM RIM WIDTH: 6.5"
REVOLUTIONS PER MILE: 860
195/60R14
DIAMETER: 23.2" SECTION WIDTH: 7.7" SIDEWALL HEIGHT: 4.6"
MINIMUM RIM WIDTH: 5.5" MAXIMUM RIM WIDTH: 7.0"
REVOLUTIONS PER MILE: 869
you would loose about .3"
Old 05-22-2003, 12:48 AM
Jfo Jfo is offline
when you say lose .3 you mean reduce fender gap space?.......
Thanks for responding to this
Old 05-22-2003, 01:44 AM
.3" ride height
you would reduce wheel gap slightly also
set your rear tire pressure @ 10psi & you will get that inch your looking for
Old 05-24-2003, 12:29 AM
Jfo Jfo is offline
is 10 psi safe to drive on though.regular tir epressure is like 35 for that tire and 10 would seem to make it bulge out and ride crappy.......and if it is true I had no idea reducing tire pressure would lower ride height.thanks for the responses
Old 05-25-2003, 02:03 AM
It was a joke. What happens if you have a flat? your ride height decreases
Old 05-27-2003, 01:21 PM
Jfo Jfo is offline
Oh missed the joke just trying to figure this out without getting new tires and them having no effect.. anyways thanks for the input
Old 05-28-2003, 01:41 AM
your answer: 185/65R14
DIAMETER: 23.5"
195/60R14
DIAMETER: 23.2"
23.5"-23.2"=.3"
if want a better answer contact Tire Rack
Old 06-28-2003, 05:08 PM
Jfo Jfo is offline
Ok so one time before i buy these 185/65/14 i wanna get it straight.....it will lower my car by roughly.3 inches but it wouldnt raise it any.becuz i want to reduce fender gap and lower my car but i dont want it to raise it any so Im making sure that the 185s would lower the car and not raise it cuz if it would raise the car any iw ould just stay with the 195 until i can get some 17s.thanks for the help
Old 06-28-2003, 05:54 PM
Go to a tire store & compare the tires side by side. You find that the difference is hardly noticeable.
