Old 05-17-2003, 07:29 PM
CivicSiR7's Avatar
CivicSiR7 CivicSiR7 is offline
Question 93 Si Won't Start???
Well me and my girlfriend bought a 93 Si for dirt cheap. The car is clean though, but it won't start. It has electrical power, I looked at everything to make sure like distributor, spark plugs, plug wires, and I'm still confused. I even used the Haynes manual to help me out if I missed anything. I even relpaced the starter with a DX starter, thinking it might be the starter and it still doesn't crank. What else could be the problem.
Old 05-17-2003, 07:59 PM
civickiller civickiller is offline
Send a message via AIM to civickiller
check the grounds and make sure the battery is good, because the battery is directly hooked up to the starter, so either the battery is no good or its a ground not hooked up, liek follow the battery ground and make sure its bolted to the chassis
Team Lonely Drivers
Old 05-17-2003, 10:35 PM
SiRII's Avatar
SiRII SiRII is offline
did the car run when you first bought it?
Old 05-18-2003, 04:36 AM
it could also be the ignition, like the key ignition. i would try get a remote starter and try do that and if it starts u know something is wrong between the ignition and the battery
Team Lonely Drivers
