Nissan Skyline GT-R Info
I'm doing a informative speech over illegal street racing and my weapon of choice is a Nissan Skyline GT-R.. I need some more info about it because all the sites I bring up don't give me enough. If you guys know any more about this car, please please hit me up.. I need to know some about street racing too if you guys know anything that would make this informative sound tight. I need an A in this class. [email protected] Thanx a bunch.
This is for a R32 GTR V-Spec
Aerodynamics Body Type Coupe Drag Coefficient (Cd) 0.40 Dimensions Overall Length 4545mm Overall Width 1755mm Overall Height 1355mm Interior Length 1805mm Interior Width 1400mm Interior Height 1090mm Wheelbase 2615mm Track Front 1480mm Track Rear 1480mm Ground Clearance 140mm Curb Weight 1500kg Turning Circle 11.0m Fuel Capacity 72 litres Engine (RB26DETT) Displacement 2568cc Bore x Stroke 86.0mm x 73.7mm Max. Power 280hp (206kW) at 6800rpm (redline 8000rpm) (under rated) Max. Torque 353Nm at 4400rpm Compression Ratio 8.5:1 Induction Intercooled (front mounted) Twin Turbo Fuel Type Premium Unleaded (or better) Fuel Consumption 12.2 l/100km Transmission Type 5-speed Floor Shift Drive Layout ATTESSA-PRO 4-wheel drive (Advanced Total Traction Engineering System for All) Differential Limited Slip Differential 1st 3.214 2nd 1.925 3rd 1.302 4th 1.000 5th 0.752 Reverse 3.369 Final drive 4.111 Steering, Suspension & Brakes Type Power assisted rack & pinion Front suspension Independent suspension multiple link system Rear suspension Independent suspension multiple link system Front brakes Four-piston Brembo calipers on 324mm ventilated rotors Rear brakes Two-piston Brembo calipers on 300mm ventilated rotors Performance 0-100km/h 4.73secs 1/4 mile (400m) 13.02secs Equipment ABS Standard Airbags No Rear Seat Belts Standard lap sash
SDU Southland Moderator |
The ones seen street racing normally have a boost increase at least.
From what i have seen on stock fuel they run low 12's with slight mods to exaust and boost pressure. Easily the best all round street car in the world. Due to price, power and looks.
