Old 05-17-2003, 01:20 AM
008's Avatar
008 008 is offline
1969 Barracuda pro-touring
Starting with an AMT '69 'cuda with the old tooling. The chassis is molded in one piece, i.e. exhaust, trans, axle is all in one multi-lumped piece of plastic. That should make my job easier to turn it into a slammed, wide-tired, big-braked, modern musclecar. Or will it?
Body was cleaned up as usual - remove mold lines, sand off emblems that are near impossible to chrome foil anyway, deepening and widening the panel lines so they don't disappear later, and sanding/fitting all the pieces to make sure they'll fit together after painting. Primed with Boyd's Testors enamel white primer; this stuff is thick! A base coat of gloss white was shot to cover the car, followed with a custom mix of gloss white/pearl blue. The end result is an aqua/baby blue/powder blue depending on what you want to call it. I FUBAR'ed the hood so it'll be flat black with hood pins - I'm too lazy to go through the strip/sand/repaint/cure/color sand/polish thing just for a hood.
Rolling stock consists of a resin-cast combination of wheels and tires from different kits. Large diameter, cross-drilled and slotted brakes will also be resin pieces. Here you see how wide the rear tires are.
For a while I was undecided between slightly widening the bodywork or creating "mini-tubs" to house the wider tires, both methods requiring quite a bit of work. I decided the tubs would be easier especially with the 1-piece chassis. With the tires against the leaf springs, they fit right under the fender (whew). With a multi-pieced suspension I would have needed to move the springs inboard if the tires didn't fit, something you can't do with the 1-piece chassis.
The pic shows where the interior was cut out. Tubs will be formed to go over the new openings. The rear seat's bottom cushion will be covered with sheet styrene for a sheet-metal or aluminum look.
Next step... ? Until next time.
Old 05-17-2003, 01:37 AM
Vyacheslav's Avatar
Vyacheslav Vyacheslav is offline
Send a message via ICQ to Vyacheslav Send a message via AIM to Vyacheslav
nice rims!
Recently completed models:
JGTC Mobil 1 NSX
Porsche 911 gt2
1985 Toyota Corolla AE86
Old 05-17-2003, 10:09 AM
stubacca's Avatar
stubacca stubacca is offline
Send a message via ICQ to stubacca
Very cool! Nice rims... :coolguy:
Life is not a journey to the grave with the intention of arriving safely in a pretty and well preserved piece, but rather to skid in broadside, thoroughly used up, totally worn out, and loudly proclaiming...
WOW... WHAT A RIDE!
Old 05-17-2003, 10:31 AM
AE86 Kid AE86 Kid is offline
Send a message via AIM to AE86 Kid
AWSOME!!!
Cant wait to see some progress!!
Old 05-17-2003, 01:05 PM
Deniz Deniz is offline
Looking great!!!
why not put some big subs where back seat is?
those rear tires look like 295-305!!! awesome
can't wait for the next update!!!
Old 05-17-2003, 01:15 PM
008's Avatar
008 008 is offline
Originally posted by Deniz
Looking great!!!
Good idea with the subs, might just do that! I was looking more into a spartan race-derived interior for the street but some speakers wouldn't hurt.
The tires are 275/40-17 front and 335/35-17 rear.
Old 05-17-2003, 01:29 PM
bah humbug's Avatar
Originally posted by AE86 Kid
AWSOME!!!
Old 05-17-2003, 11:40 PM
Purpura Delujo Purpura Delujo is offline
Looks great, what colour you going to do the interior? It would look alot better as a show/street car than a race car.
Old 05-18-2003, 08:58 PM
Juan Robles's Avatar
Juan Robles Juan Robles is offline
I realy like to see nice street machines in the forum.
Keep the good work and give up dates.
Old 06-11-2003, 01:43 AM
008's Avatar
008 008 is offline
Sorry for the lack of updates, I had to finish the hotrod really quick and when I got back to this one I didn't take any more progress pics. Here is the end result. I didn't do any engine detail because the 1 piece chassis is garbage in the first place so why bother. I did what I could to the underside and it looks fairly decent. The resin tires were white and I painted them with Floquil "Grimy Black" which looks close enough to rubber. Exhaust tips are 1/8" tubing covered with BMF. Body is painted with automotive base/clear system; the color is "Smoke Metallic" which I believe is a Ford 2002 color. Enjoy, thanks!
edit - Oh, and why the color change, you ask? I was painting the underside of the body black when the body slipped and hit the airbrush on the way down. Since I was using a color cup and not a bottle I spilled black paint on the beautiful baby blue. The paint was so thin I couldn't rub out the black without rubbing the original paint off, so I stripped it all back down to plastic. Fun time with this model!
Old 06-11-2003, 02:26 AM
Only thing I think you should do is foil the window trim & door handles. Then do the indicators and you'll have a really fine looking `Cuda!
Old 06-11-2003, 06:32 AM
ZoomZoomMX-5's Avatar
Thumbs up Cool model!
Came out nice. Saw it on Ebay, why you selling it?
My Fotki Album
Old 06-11-2003, 11:51 AM
CamaroSSBoy346's Avatar
CamaroSSBoy346 CamaroSSBoy346 is offline
Send a message via AIM to CamaroSSBoy346
how did you get the super stallion wheels all up on that metal axle?
2002 F150 SuperCab FX4 6" Fabtech, 3" BL, Detroit locker, Edge tuned, Yukon 4.56s, 37" Nittos, Harley lights, Depo fogs, 8K HIDs, Powerstop brakes
1992 Lincoln Mark VII LSC 302 H.O, A9L ECU swap, 65mm TB, 73mm Granetelli MAF, FRPP 30lb injectors, Walbro 255, MSD ignition, Powerdyne BD11 supercharger, Efans, T-5 swap w/ FRPP flywheel, Ram HDX clutch and adjustable Steeda clutch quadrant, 4.10 gears, Nitto NT555R radials
2000 OBS Tahoe Z71 6k HIDs, 33" Goodyears. 280k mile daily beater
Old 06-11-2003, 01:36 PM
Midnight Racer's Avatar
Great colour choices.Great job.
Old 06-11-2003, 02:24 PM
Looks awesome. Those rims suit it well.
