Old 05-16-2003, 10:40 PM
jengle jengle is offline
metro engine question
For my senior project this year I decided to build a go-kart and put a metro engine on it to beef it up a little. I have already made the frame and everything but and having some troubles with the engine. I dont want the ECM on my go kart so I bought an old beetle carb of of ebay and with an adapterit will be my carb. However, I don't know what to do about the distributor because it also relys on the ECM. Any suggestions?
Also, I know that one cylinder has low compression and needs to be fixed but before I take it apart, is there any common problems with low compression. I figure that it is either piston rings or valves but am not sure.
Old 05-16-2003, 11:23 PM
2strokebloke's Avatar
2strokebloke 2strokebloke is offline
In Stereo where available
Let us hope for your sake that the frame you made is strong enough!!!
Please explain ECM (what does this stand for?)
Also, a beetle carb is going to be WAY to big for the Geo engine, the carb probably came off of a 1300cc engine or bigger, and the Geo engine is under 1000cc displacement!
Support America's dependence on foreign oil - drive an SUV!
"At Ford, job number one is quality. Job number two is making your car explode." - Norm McDonald.
If you find my signature offensive - feel free to get a sense of humor.
Old 05-17-2003, 12:42 AM
SROfirefly1_0 SROfirefly1_0 is offline
Send a message via Yahoo to SROfirefly1_0
electronic control module.
its all about the twisties
Old 05-21-2003, 07:05 AM
Yeah,
ECM = Computer
I found this website on someone who did almost the same thing but I dont know where he got his distributor. I've heard that if I connect the positive battery to one end and negative to the other of the distributor, it'll work. Has anybody else heard this?
Old 05-21-2003, 07:07 AM
oh yeah, here's the website.
http://ttt-ranch.net/ttt-discoverer/...fications.html
Old 05-21-2003, 03:38 PM
Yeah, he got the distributor from a 91 Geo metro,any 91 or earlier should work. (maybe even a Chevy Sprint)
Old 05-24-2003, 02:17 PM
So 91 or earlier metro distributors do not have a connector wire that connects to the computer? Is there a way that I can just use mine now without a computer?
Old 05-24-2003, 06:32 PM
I have no idea, because I'm not a Geo expert, but I don't think that pre 91 distributor should be too hard to find, also the carb he is using is not a stock VW carb, it looks like it's part of a dual-carb upgrade kit for VW's and is actually smaller than the stock VW carb.
Old 06-16-2003, 04:11 PM
robert erickson robert erickson is offline
dude!! dont use a geo!!!! the engine is heavy and gut less. its built fore fule economy. use a bug motor there cheeper, more realiable, good gass miles, easy to work on, lighter. more power no radeator, and parts are every where.
Old 07-13-2003, 07:51 PM
geozukigti geozukigti is offline
If it's got low compression, it most likely needs a valve job. They have a bad habit of burning valves on the SOHC 3 cylinders. A 3cyl turbo motor would probably be your best bet for a go-kart motor. small, light, and 100Ft-Lb's of torque. You can pick one up from a junk yard for fairly cheap.
Old 02-03-2006, 06:55 AM
leonbentz's Avatar
leonbentz leonbentz is offline
Send a message via Yahoo to leonbentz
Re: metro engine question
There were certain models of Metros that were built in Canada, that had the older style of distributors and they didn't require an ECM to operate it. Mine is one of those. It has the old style of vacuum advance. As far as carburation? Hmmmmmm, I think three side draft carburators from a Honda 750 street bike would be awesome. I think if you get the LSI engine, it'll have plenty of spunk for a go-kart
Old 02-03-2006, 06:57 AM
leonbentz's Avatar
BTW, 2strokebloke.....cool pics of the little Subaru on your post there. Those are cool little cars. I seen a couple of those in the past. They're extremely rare now and make a good collectors item.
Old 02-03-2006, 09:08 AM
Crvett69's Avatar
Crvett69 Crvett69 is offline
if you get a intake off a JDM engine some of them came with a carb. if you get a distributor off a 91 or older with vacuum advance it does not need the computer to work. the stock metro engine puts out 55hp, thats probably more than you need for a go cart, engines weighs 125 pounds complete with oil. you will need to rig up a radiator with electric fan. the jdm engines run about $300-350 and most places sell them with a warrenty
Old 02-03-2006, 09:20 PM
leonbentz's Avatar
What causes them little boogers to burn valves, anyhow? Is it because of a bad lifter design? These are hydraulic lifters, aren't they?
Old 02-04-2006, 08:20 AM
Tominator2000 Tominator2000 is offline
The EGR passages clog up with carbon and the #3 cylinder is the first to go.
The Holley Bug Spray should work fine if jetted properly, but a popular mod is to use motorcycle carbs.
All Geo Metro cars except the convertible that was made in Japan and part of one year in California, were assembled in Canada and as stated the '91 and earlier cars used a vacuum advance distributor.
Not to detract from this forum, check out http://www.teamswift.net/index.php
