Old 05-16-2003, 06:40 PM
mrchris1979 mrchris1979 is offline
SOHC VTEC manifold w/ CRX SI throttle body
Can I use the intake manifold from a '94 SOHC VTEC with an '89 CRX SI throttle body?
Will the injectors from the CRX SI fit in the fuel rail from the SOHC VTEC fuel rail? Since the injectors from '94 civic do not use the resistor pack.
Old 05-16-2003, 08:48 PM
91civicDXdude's Avatar
first off, the injectors will fit with no problems whatsoever.
However, the D16A6 (SI) throttle body will not fit on the D16Z6 (sohc vtec) intake manifold. Any throttle body from 92+ will fit on the z6 manifold however, including B16A2/3, GSR, LS, etc.
Old 05-16-2003, 10:03 PM
Thanks for your time..really appreciate the info
